Old 02-07-2012, 02:17 PM
noiseless64 noiseless64 is offline
Default Fast Track Ultra 8R + Eleven Rack both in PT10: Incomplete operation
Hello, I have the Fast Track Ultra 8R together with PT 10 operational. I recently bought the Eleven Rack and connected it with my PC and with SPDIF cables with the FTU8R.
The strange thing is that in recording mode everything is working fine. I can record a guitar signal via the true-Z input of the 11Rack and SPDIF out through the FTU8R and then into PT10. The 11R Operation Window in PT10 is fully operational.
But when I open the Setup menu in PT10, the 11R is NOT visible in the "hardware setup" tab. Curiously, in the next tab "Playback engine", the 11R is present ! Because the 11R is not in the hardware setup, I can not choose in PT10 which device must be the external or internal sync source. And in audio-tracks I also can not choose SPDIF as output of that track. I suppose that's part of the same problem. And because of this I cannot RE-AMP in a normal way !!
Is there something I've missed ??
With kind regards, Andre
New PT10 User. MBox3, MAudio Fast Track Ultra, MAudio Fast Track 8R? epu Pro Tools 10 3 06-13-2012 03:55 PM
Fast Track Ultra 8R & Eleven Rack in PT10, Re-amping not possible noiseless64 Pro Tools M-Powered (Win) 0 02-12-2012 10:32 AM
hi there does the fast track ultra rack work with standard pro tools 10? Corebeatz Windows 3 01-27-2012 03:37 AM
Eleven Rack + Fast Track Pro mhelm01 Eleven Rack 3 01-07-2011 11:05 AM
track confusion in fast track ultra interface deck Pro Tools M-Powered (Win) 0 02-24-2010 10:17 AM
