Old 02-16-2011, 04:53 AM
Detlef Brockmann Detlef Brockmann is offline
Default 6-core (3.33GHz) or 2 quad-core (2.4GHz) Westmere
Hello everyone,
so I want to replace my G5 and have to decide between the 6-core (3.33GHz) or the dual quad-core (2.4GHz) Westmere processor setup.
I usually have mid size mixes (64 tracks) and a couple of VIs.
I know that ram has a lot to do with performance but just to keep it simple I want to choose between these two setups.
Cheers, Detlef.
Old 02-16-2011, 05:20 AM
chrisdee's Avatar
chrisdee chrisdee is offline
Default Re: 6-core (3.33GHz) or 2 quad-core (2.4GHz) Westmere
I would go for the 6 core for no other reason than having the fastest and newest technology at hand.
Old 02-16-2011, 03:24 PM
SixChurchStreet SixChurchStreet is offline
Default
I'd also go for the 6. I like the math.
Mac Pro 5,1 2.4GHz 8-Core 16GB RAM High Sierra | Focusrite Scarlett 6i6 Mk2 | Pro Tools 2020 | Studio One 4
Old 02-16-2011, 04:36 PM
Matt Stutter Matt Stutter is offline
everymac.com has a great comparison with theoretical 'geekbench' scores where you can compare. According to the numbers, there isn't much in it - the 6 core is slightly quicker tho.
The dual quad can hold 64GB of RAM - should you ever choose... And comes with more to begin with. BUT, the 6 core has faster RAM... Sheesh.
Seems like most apps don't really spread out over the cores that much, and faster/higher clock speed is the important bit.
Old 02-18-2011, 07:08 PM
[email protected] stvbn@yahoo.com is offline
....just remember that PT9 can currently access 4gigs of ram as an appication / 32 bit program. sad to say, i found this out after stacking up 16 gig of ram on my dual core nehalem mac.
i also run 64 tracks, no issues here, with proper system setup, processor selection ,etc.... run your activity monitor app on your mac it, will show you what is using your ram, it may also suggest that you can save a little on ram and buy more plug ins.... (what i wish i had known....system and PT9 using about 5 gigs and often, 9 to 11 gigs available for surfing the web, itunes,celemony melodyne..
-SteveB.
6-core (3.33GHz) or 2 quad-core (2.4GHz) Westmere Detlef Brockmann Pro Tools TDM Systems (Mac) 9 02-21-2020 10:39 AM
HDX-2 on (slightly revised) 12-core 2 x 2.4GHz 6-core Intel? / RTAS in PT10HD MixerGuy Pro Tools HDX & HD Native Systems (Mac) 10 06-18-2012 07:10 AM
Mac Pro 3.33Ghz 6 core Westmere & VE PRO johnpaulgeorgeringo Pro Tools TDM Systems (Mac) 36 01-02-2011 09:35 AM
2010 mac pro 2.4Ghz 8 core vs 3.33Ghz 6 core edadema Pro Tools TDM Systems (Mac) 32 09-07-2010 07:36 AM
Single core vs. dual core vs. quad core John Peeples Tips & Tricks 9 11-07-2007 03:28 PM
