Old 12-09-2002, 05:00 AM
nigel smith nigel smith is offline
Default Digitest board failures
While trying to run 3 tdm fx sends on a session, I got repeated DAE error -7207, which alerted me to the fact that our Mix Farm card didn't seem to be doing anything.
Running digitest I found both boards failed.
Mix Core failed as follows:
TDM Transmission Test Dsp (A): TDM Pattern Not Start
Mix Farm failed as follows:
TDM Transmission Test Dsp (A): (Failed 7 times) NO TDM clock detected
Any idea what is causing this problem?
Pro Tools HD Native 10.3.7 on Nehalem 2.8 Quad core with 16Gb RAM.
Old 12-09-2002, 05:47 AM
orbital orbital is offline
Default Re: Digitest board failures
check that you have TDM ribbon seated correctly and that the i/o interface is connected and swithced on
Old 12-09-2002, 07:36 AM
thanks - the ribbon cable was loose.
DIGITEST - some failures for MIX FARM CARD GC101 Pro Tools TDM Systems (Mac) 1 04-09-2007 10:41 PM
BOARD TECH NEEDED to service Amek Matchless board audio[LAB] General Discussion 4 01-31-2007 11:17 AM
Digitest failures rubberlugs Pro Tools TDM Systems (Mac) 2 05-10-2005 09:35 AM
192 Interface Failures Above Normal? John McDaniel Pro Tools TDM Systems (Mac) 1 11-01-2004 08:11 AM
Digitest TDM cards and Control 24 Board audio101 General Discussion 2 01-26-2001 03:55 AM
