Err (-6104) CPU Usage is holding off USB audio
Every once in a while I get this error but my H/W buffer Size is set to 2048 samples. Anyway to get this err box to stop?
MacPro (4 Processors) Mbox2 Micro Satellite LE (For HD Video Files) Playback Engine: Playback Buffer is Level 4 Cache Size Large Plugin Streaming Buffer Level 8 Optimize for streaming content on audio drives is checked. Not sure what else I can do? |
Re: Err (-6104) CPU Usage is holding off USB audio
This question should be posted in the LE forum, not the HD one, but since I have both and have seen this error:
Set Hardware buffer for 512, or 1024 *max*, or otherwise as low as is practicable unless you get errors *specifically* recommending that you raise it (generally for high plug-in counts). A buffer of 256 or lower may be just fine depending on what you do. This will also greatly reduce latency on any VIs you might use. Set DAE buffer at 2 unless you get errors *specifically* telling you to raise it (generally for high edit density or a slow hard drive). Not sure about "plugin streaming buffer", but otherwise this should do the trick.
Ted Spencer, NYC tedspencerrecording.com |
Thanks, actually I have an HD system synced to an LE system so kinda an LE/HD question because not sure if it had something to do with the HD satellite link?
Right, well anyway, give what I suggested a shot. I have seen the settings you described cause the exact error you cited on LE systems, at least with laptops, and the one I suggested solved it. Hopefully it'll work for you too.
CPU Usage holding off USB audio (-6104) | SnakeyD2 | macOS | 1 | 09-11-2013 10:14 AM |
CPU usage is holding off USB audio. (-6104) | acarrico86 | macOS | 3 | 01-28-2012 11:30 PM |
Error: (-6104) CPU usage holding off USB Audio | twirk | macOS | 2 | 12-15-2011 07:14 PM |
CPU Usage Holding off USB Audio -6104 error | Mark Mangini | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-11-2010 07:05 AM |
CPU Usage is holding off USB Audio... error -6104 | redrider307 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-27-2006 09:51 AM |
