Old 04-12-2006, 03:28 AM
potex potex is offline
Default General Troubleshooting Guide problems..
I just used the General Troubleshooting guide to hone my system and I think it actually made it run worse!
There is a contradiction in there:
It says this at the start:
"- To Adjust Processor Scheduling Performance:
Choose Start > Control Panel. In Classic View, launch System. Click the Advanced tab. Under the Performance section, click the Settings button. Click the Advanced tab. Under the Processor scheduling section, select the Background Services option. Under the Memory Usage section, select System cache option. Click OK twice. You will need to restart your computer for the changes to take effect."
Then this towards the end:
" Then click on the Advanced tab and set both Processor Scheduling and Memory Usage to 'Programs.' Close the Performance Options and System Properties windows by clicking 'OK.'"
So which one is it??
Also I found that by turning my color mode to 16bit and turning off hardware acceleration for graphics my higher end plugins like my Waves SSL started to blow out and have errors in their display and the level meters would function very jerky and slowly. If you have a decent video card wouldn't you want harware acceleration enabled so that it can do its job?
-Ben
Old 04-12-2006, 12:41 PM
Default Re: General Troubleshooting Guide problems..
Bump ...maybe Shawn can help you with this one.
Aaron Mulqueen - 001 HD Native
Old 04-13-2006, 07:29 PM
Could I please get a reply from digidesign om this?
You tell us to set processor scheduling one way then the opposite within the same guide.
Thanks
Old 04-14-2006, 03:45 AM
x9blade x9blade is offline
i noticed this the other day and i was also wondering the same. I also expierenced the same problems you described with my ssl bundle.
only thing i can think of is, it does say IF your having problems then try the later suggestion.
3930K I7,X79 asus,GTX780,Samsung SSDx2,Western Digital Black 2TB HDDx4
32 Gb Corsair ram,30"Apple Cinema Screen,HD NATIVE
where is general troubleshooting thread? bruce_pianoman macOS 1 04-20-2013 03:38 PM
Really could use the General Troubleshooting and What You Need To Know stickies here! cwsand Windows 3 06-05-2011 01:08 PM
General Troubleshooting - Pro Tools on Mac OS X DigiTechSupt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 05-11-2010 02:30 PM
Re- General Troubleshooting - some problems shilshoolon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 06-28-2007 03:01 AM
General TroubleShooting Tips Mentalist 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-26-2005 07:17 PM
