Old 06-11-1998, 03:29 PM
Ivan G Castro Ivan G Castro is offline
Default ML2.0.1 @ AMIII
My ML don't recognize AMIII,When I select in the hardware set up AMIII,I don't have sound,
I can oly get sound when I select Mac Internal Sound Card. maybe the AMIII is in the wrong slot (My AMIII is in O slot.)
Old 06-14-1998, 08:18 AM
Oliver M Oliver M is offline
Default Re: ML2.0.1 @ AMIII
I installed my AM III in slot 1, slot O is used by my graphics card. Maybe you try slot 1?
Old 07-14-1998, 05:35 PM
Larry LaLonde Larry LaLonde is offline
If your using Digi System INIT 3.2.3 and the AMIII card there is a known problem. Either install DSI 3.3, revert back to 3.1.1 ect, and or wait for the release of PT's 4.2.
Good luck,
Larry
Old 07-15-1998, 10:57 PM
J Cuniberti J Cuniberti is offline
Same here, I will move to slot 1 and advise. By the way, I could not download INIT 3.1.1 from Digi site as of 7/15.
Old 07-15-1998, 11:20 PM
No change in slot 1. I guess I will have to pay more money to get what was promised..right?
Old 07-20-1998, 12:50 AM
DigiTechSupt's Avatar
Again, Larry is correct. Changing slots is not going to remedy the problem between MLCD 2.x and DigiSystem Init (DSI) 3.2.3 on the AM III card.
I'm not sure why you were not able to download DSI 3.11 from our website but there is no cost to do so. You may want to try to download it again, if you are still unable to successfully download it let me/us know and I'll email it to you.
Thanks,
Jon Connolly
Avid Audio Tech Support
Support FAQ
Old 07-20-1998, 08:36 PM
Is Larry right about 4.2 fixing this problem?
Old 08-11-1998, 10:53 PM
Well, It's been a long hot month and I guess I have my answer........thank you
HTML code is On
Who's in charge of AMIII development? This AMIII business has gone on far too long. sixgun General Discussion 2 01-05-2005 09:27 PM
Help - G4/Mix+/AMIII roderickelms Pro Tools TDM Systems (Mac) 1 06-09-2003 10:11 AM
G4 and AMIII Grey Pro Tools TDM Systems (Mac) 0 11-17-2000 02:20 PM
pt4.3-os9-amIII-i cant find amIII card?? guell1 Pro Tools TDM Systems (Mac) 1 06-15-2000 01:49 AM
Using 001 and AMIII? Jasper 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-04-1999 06:17 AM
