Old 06-10-2018, 07:27 AM
FroTools12 FroTools12 is offline
Default Had "12" Now seems like being pushed to "2018"
Hi. I was running pt 12 on a p.c. By monthly sub.
Now I finally have my mac, I logged into my avid account, and when I look at my products and d/l page, it doesn't indicate 12, only protools 2018. Should I go with that? What happens to compatibility if I want to say, start on the mac and for some crazy reason put it on my pc?
Thanks
Old 06-12-2018, 01:01 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: Had "12" Now seems like being pushed to "2018"
So if you have an active subscription you can start an support case and ask for Downloads for 12 (whichever version you like). They should get a download for you rather quickly
Depends on what works for you. What version did you last use? What OS do you have on your mac? What version do you have on your PC? Many people use different OS's but you have to find a middle ground of the latest OS and the latest PT version that works for you.
PT versions are typically pretty good at working with each other...for example I would not imagine you have a problem jumping between Mac 12.5 and Win 12.8....at some point that might change but as for myself I don't have an issue doing that.
Daniel
Old 06-12-2018, 02:03 PM
simonchase simonchase is offline
Sessions are backwards and forwards compatible. I think as far back as v10. Maybe only v11. But obviously if you use features that are past a certain version they will not translate. (Clip fx, atmos, etc?)
PT Ultimate 2023.9.0 - MacOS 13.4 - MacBook Pro (Late 2019) - 2.4 GHz 8-Core Intel Core i9 - 64 GB 2667 MHz DDR4 - Apogee Quartet - Avid Link 2022.12
"High" Sierra Better For 2018 Than "Plain" Sierra"? GTBannah Pro Tools 2018 20 02-23-2018 09:06 AM
Keyboard Shortcut for "Track List", "MIDI Editor Pane", and "Clip List" EdgarRothermich Pro Tools 12 2 10-04-2017 02:18 PM
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? bashville Pro Tools 10 5 03-23-2013 03:04 PM
hardware buttons for "preview", "capture" and "punch" evs Post - Surround - Video 1 12-06-2010 12:28 PM
The "FATE" of CM LABS "MotorMix" & "MotorMate". Dum dum dum dum... leon777 Pro Tools TDM Systems (Mac) 21 10-15-2002 12:00 AM
