Old 09-16-2018, 12:54 PM
Joolaitha Joolaitha is offline
Default [SOLVED] Cannot UNmute grayed out midi region
[SOLVED] After trying several fixes, I highlighted the grayed out section and clicked EDIT>CLEAR (Command+B). Then I highlighted the preceding bars of midi drum pattern and selected EDIT>REPEAT (Option+R) and replaced the cleared midi sections. Worked perfectly.
__________________________________________________ __________________________________________________ _________________________
I muted a few bars of a midi drum track. When I attempt to unmute it, it won't allow me to do so. I tried COMMAND+M, which mutes/unmutes under normal circumstances. I also tried deleting the grayed out region and copy/pasting another region with the identical rhythms but that doesn't work either. Can't figure it out. Anyone come across this?
PT 10.3
2.3gHZ i7
8gb RAM
MacMini
Old 09-17-2018, 05:02 AM
Default Re: Cannot UNmute grayed out midi region
Do you have the whole track muted? Can you unmute by right clicking and selecting 'unmute'?
Could use a bit of help from you though. Your profile says you're running PT10.3 on Win8 which if true is not considered a compatible combination. Which exact version of PT10 are you running? Or are you running PT10 in OSX and if so what OSX do you have?
The next obvious question is why not run PT10 inside OSX assuming you have a compatible OSX version that'll run PT10.
Jack
QAPLA!
Old 09-17-2018, 06:13 PM
Thanks. I do not have the entire track muted—only the midi drum track. Right-clicking and selecting "unmute" has no effect. Neither does COMMAND+M, which are the keystroke commands for mute/unmute.
I actually am no longer running Bootcamp (WIN8) on the MacMini. I am now running the Mac OS that is compatible with PT 10.3 (which basically means I can never upgrade my OS or I'll have to upgrade PT and AVID has now gone to the "pay annually to upgrade" program, which is an expense I don't want). I am pretty sure the Mac OS is Sierra but I'm away from the studio right now and can't verify that til t'mow. Below are the current system specs.
Thanks again for your reply.
Mac Mini i7 2.3 GHz; 8GB RAM; Sierra(I think); 64-bit; Pro Tools 10.3 with Apogee Quartet.
Old 09-18-2018, 12:36 AM
tonwurm's Avatar
tonwurm tonwurm is offline
maybe your midi track has lose its assignment to the instrument. that´s an old bug in PT. try to assign it again and see what happens...
MP5,1 12core 3.46ghz 96GB
Ultimate HDX
https://www.youtube.com/channel/UCIA...Rnu0Jfh-YsgftQ
Old 09-18-2018, 04:35 AM
You really should fix your profile page. When you do that also put in the exact PT10 version you're running. Sierra is NOT compatible with PT10. The last PT10 compatible OSX is Mountain Lion OSX 10.8.5 but a lot of people using OSX 10.9.5 (Mavericks) are also running PT10 no problem; the only issue is the uninstaller for PT10 doesn't work in Mavericks.
Of concern if you are running Sierra how did you get it on your machine? Did you do an in-situ OSX upgrade installing Sierra over whatever was on the computer to begin with? That's not a good thing as all kinds of compatibility issues can crop up which could be the root of your problem.
Jack
QAPLA!
Old 09-21-2018, 05:03 PM
Thanks for your reply. I was mistaken, I am actually running OS X. I updated my system profile. I am going to tackle the issue the problem again and see if I can unravel it. I appreciate your input.
Region grayed out! Acustiman Pro Tools 10 7 10-06-2015 03:32 PM
Speaker mute,unmute, record track mute,unmute for ADR garret Post - Surround - Video 7 09-04-2015 01:03 PM
BUG? FEATURE? Fades over region groups unmute underlying audio! reichman Post - Surround - Video 1 07-27-2009 01:17 PM
Can't capture region - grayed out pixel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 02-09-2004 07:51 PM
mute/unmute region command changed? mixaudio Pro Tools TDM Systems (Mac) 4 05-26-2001 09:04 AM
