Installing Multiple DAW's on one machine
hey Folks,
just wondering if there has or is issues having multiple DAWs installed on one machine. Not to be able run at the same time, I would probably quit whatever Daw was running and restart my machine before starting one of the other DAWS. I would like to add Cubase 9.5 or Studio One, it will depend on what Digital desk I get. thanks for any feedback cheers Rob
Rob MBP 15 2018 macOS Big Sur 11.6.8 Touch Bar and ID 2.2GHz 6 core 8 gen Intel Core i7 processor (TBs to 4.1GHz) 32 Gb of 2400MHz DDR4, 1T SSD, Magic Mouse and Keyboard Pro Tools 2022.7 -23.# - HEAT applied, RME Fireface UCX II ........and a bowl of M&M's |
Re: Installing Multiple DAW's on one machine
Depending on how each plugin saves presets ones you create when in one daw might not be available in the other. I wouldn't try and have both running at the same time though. You don't have to restart the computer when switching daws - just quit say PT and launch the other daw. An oddball thing on my system is that every once in a while when I've used PT and switched to DP when I go to shutdown for the day the computer will hang. I have to call up Terminal and use this command (pay attention to the spaces): sudo shutdown -h now and when prompted enter your system password and in a short while the computer will shut down. If you don't want to shutdown but reboot replace the -h with -r |
No problem
Ive got Cubase, Logic, and Pro Tools installed
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro S1 x 2, Fire Max11 x 2, Dock, iPad Air5 Mac Mini 14,12, 12 core, macOS 13.6.6 RAM 32GB, SSD 4TB, GPU 19 core QNAP TVS-872XT 148TB TB3 |
Pro Tools, Harrison Mixbus and Live here.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro PT 2023.3 Studio through an A&H Qu-32 |
No problems. Pro Tools, Pro Tools | First, FL Studio, Studio One, Reason installed here.
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Indeed, the DAW software SHOULD be fine...BUT....(a great big BUT), do yourself a favor here and cover your ASSets. Assuming your system is working well with 1 DAW, back this up with a drive image, or clone your system drive to another drive(a good idea for all of us, anyway). That way, if things go sour(like they did for me), you can restore from the drive image, or swap the cloned drive in, so you can get work done. I never figured out why, but a co-install of Studio One(this was over a year ago) completely hosed my rig. I was able to restore from a drive image, so no harm done, but without that image, I would have been reloading every piece of software I own
Works here too:
Logic Pro X (Latest) Harrison Mixbus v4 & Mixbus 32Cv5 Harrison Mixbus (32) has been a wonderful go to for times when PT and the latest MacOS seem to be at odds.
Pro Tools 2019.5 Perpetual / iMAC 27 Retina i5 3.3 Ghz Skylake, 32GB Ram, 256GB Flash / 1TB External 7200 RPM Audio Drive, Mercury Pro CD-DVD Burner USB-3 /Glyph Studio 3 TB Sample Drive OS X-10.14.4 Mojave Focusrite Clarett 8preX/Audient ID22 / UA Apollo Twin Duo-Thunderbolt / Harrison Mixbus and Mixbus 32c/ Wavelab Pro 9.5/Cubase Pro 10/ Logic Pro-X/Final Cut ProX/NI Komplete 10/Reaktor 6/ Kontakt 6/Cinematic Studio Strings/Solo String/Piano/ Synthogy American Steinway D/Superior Drummer 3.0 NY Studio/Omnisphere 2.6/ Collection/Waves Grand Masters/Waves Abbey Road Plates/Waves Gold/Waves H-Delay&H-Comp/Many UAD2 Plugins |
As has been mentioned, you can have more than one DAW installed. Many of us use Reason and Reaper in Rewire mode inside Pro Tools, as an example. But, they can also be run individually as well, all on the same machine. I've run Reason and PT at the same time, too, in order to take advantage of Reasons ability to host VSTs since version 9.5, which Reason can't do in slave (Rewire) mode. But, you may run up against CPU limits.
One at a time is best, but having them each installed, hasn't, to my knowledge, caused any issues.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones Owner: Dragon Rock Productions LLC |
Pro Tools, Logic and Reaper here! No issues. I can even play iTunes/YouTube while Pro Tools is bouncing in real time in the background. What an age we live in (and what are the kids using this technology for? Trap music? )
Multiple Instances of PT9 on same machine possible? | Matt_G | macOS | 5 | 06-16-2011 08:17 AM |
Installing Pro Tools on second machine? | Colin_09 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-12-2009 02:54 PM |
Installing Tiger on the new machine | Smithcok | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-19-2008 10:44 AM |
Installing LE 6.1.1 - 002R on XP machine w/ SP2 | geewho | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-07-2005 07:49 PM |
Machine Control Multiple 9-Pin? | steppenwolf68 | Post - Surround - Video | 2 | 03-18-2004 12:02 PM |
