Old 10-14-2017, 03:58 PM
mjbarry mjbarry is offline
Default Re: Click ahead of counter...doesn't sync with grid
Where would I look for that? I'm still learning PT....and yes, the counter is set to Bars and Beats.
I think the last time I worked with PT I was importing a midi file (organ) and using Kontakt player for an organ sound.
Like I said earlier, it looks like it's exactly 1/8th note off.
Thanks!
Mike
PC - i7 3Ghz, 12 GB RAM, TI 1394 card, Windows 7 Pro 64 bit.
MBox Pro
Pro Tools Win - 10.3.9
Old 10-14-2017, 07:20 PM
Open the Pro Tools reference guide already installed with Pro Tools and search for things there...
Old 07-30-2018, 03:47 PM
Default SOLVED!! Re: Click ahead of counter...doesn't sync with grid
Unreal.
It turns out the problem was the lag in the monitor I have. I switched it to GAME mode and the problem went away. I have an Insigna NS 32L550A11 TV that I have used as a monitor for years now.
I was able to narrow it down when I installed the free version of Studio One to try out. I noticed that the problem was exactly the same in that piece of software and Pro Tools. A little sleuthing in the TV menu and I finally figured it out.
I wanted to make sure I posted the solution, since it's so oddball, and since no one was able to figure out what the problem was.
MBox Pro
Old 03-04-2023, 01:20 AM
dmh_ dmh_ is offline
translated by google
problem solved!
after several attempts ...
I found that the problem of synchronizing between click track .. midi sync .. and pro tool 7.3 ... It is solved by placing a usb memory drive before starting pro tool ..
Audio Recorded from MIDI track ahead of the beat/grid CalebB macOS 1 10-22-2012 11:03 PM
Sync Grid Lines To Click Track nickacuff1289 Pro Tools M-Powered (Win) 3 02-16-2012 04:13 PM
Main Counter doesn't update when I click the timeline Grizz1978 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-25-2011 06:40 PM
External click track ahead of session Carpedrum 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-04-2010 04:43 AM
Click / Grid doesn't line up anymore econoline 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-15-2010 06:40 AM
