Old 05-11-2013, 01:34 PM
jschmidtiii jschmidtiii is offline
Default Mapping the tempo of a track the changes continuously
I have a track that changes time continuously and I'd like to be able to make a tempo map so the click stays with the track the entire time. I've done my research on line and it seems everyone solves this problem with the "identify beat" command. They will highlight something like 4 bars, say it starts on bar 1 and ends on bar 5, and then one tempo change will be made. The problem is that the click begins in time but is out of time by the end of the four bars. If I want to do this properly do I have to identify beat ever bar? That seems nuts.
I'm sorry for the silly question but I can't seem to find the answer. Thank you.
Old 05-11-2013, 02:20 PM
Stig Eliassen's Avatar
Default Re: Mapping the tempo of a track the changes continuously
The best method depends on several things. How tight you need the tempo map to be, how defined the rhythm/transients are in the audio you're mapping to, how variable the tempo is in the audio, etc.
Identify Beat works fine, but using it down to every beat gets tedious fast.
Beat Detective also works fine if the audio has pretty clear transients, and a relatively steady beat, and you can create Bar|Beat markers in pretty big chunks at a time.
You can also record yourself tapping, say, quarter notes on a MIDI keyboard, and then analyze the notes with Beat Detective to create a tempo map.
Continuously writing (or tapping) tempo track in real time stevegalante macOS 3 04-22-2013 08:03 PM
Continuously Variable Track Height - crashing 8.0.1cs2 (PPC) jeremyroberts Pro Tools TDM Systems (Mac) 5 07-20-2010 12:13 PM
continuously variable mix window track size paulreed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-02-2009 07:46 AM
Tempo Mapping KingStudios Pro Tools M-Powered (Mac) 0 06-05-2008 01:50 PM
Really Need Help With Tempo Mapping tomhartman Pro Tools TDM Systems (Mac) 1 08-03-2001 05:50 AM
