Old 07-15-2013, 01:28 PM
Cliffy_Boy's Avatar
Cliffy_Boy Cliffy_Boy is offline
Default Audio Dropouts
Anybody getting these in PT11 HDX?
Lately every 10 or so minutes I'll get one, or even a few. Annoying when I'm bouncing as the dropout gets recorded.
I'm using a mix of AAX and AAX DSP plugs, several outboard using either analog or AES hardware inserts.
Using a Mac Pro 8 core Westmere with 32 G Ram
Old 07-15-2013, 02:27 PM
Park Seward's Avatar
Park Seward Park Seward is offline
Default Re: Audio Dropouts
From the Reference Guide. Are these the type of errors you are hearing?
The Ignore Errors During Playback/Record option determines how Pro Tools responds to error re- porting from the Avid Audio Engine (AAE) during playback and recording. This can be useful when working with instrument plug-ins where you care less about clicks and pops in the audio signal while you work on composing and arranging. Once you are ready to work on the final mix you should disable this option. Observe the following guidelines as to whether or not to enable or disable error suppression:
• Enable error suppression only if you are experiencing frequent errors that are interrupting your creative workflow. When error suppression is enabled, you can experience a degradation of audio quality. However, this may be acceptable in order to avoid interrupting playback and recording when working with instrument plug-ins.
• Disable error suppression when you need to ensure the highest possible audio quality, such as for a final mix.
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 07-15-2013, 02:34 PM
Cliffy_Boy's Avatar
Thanks Park
No. I have error suppression un-ticked.
When I'm playing back a mix, there will be a sudden dropout on a fraction of a second and then the audio will continue. The dropout is within Pro Tools as it will appear if I hear the dropout during a bounce or RTD.
The entire session drops out and not just tracks going to outboard.
I had this problem with new PT 10 HD versions (10.3.2 and up) as well as PT 11.01 HD
Old 07-15-2013, 02:42 PM
Ok, What external drive are you using? What OS version?
Does the dropout happen at EXACTLY the same place or is it random? Any bad cables?
Park
Old 07-15-2013, 02:45 PM
Cliffy_Boy's Avatar
OSX 10.8.4
Internal drive 2
Random areas.
Thanks!
Old 07-15-2013, 02:50 PM
jasonthurley's Avatar
jasonthurley jasonthurley is offline
Have you tried increasing buffer size?? like to 1024??
-Systems Engineer, Systems and Sound Designer, Recording and Mixing Engineer
Old 07-15-2013, 03:17 PM
Originally Posted by Cliffy_Boy View Post
OSX 10.8.4
Internal drive 2
Random areas.
Thanks!
What kind of drive (RPM, size, manufacturer, age)
Park
Old 07-15-2013, 03:41 PM
Cliffy_Boy's Avatar
any buffer - 64 to 1024 all have the same issue. The drive is the one that comes with a mac pro. Not sure which. never had problems on earlier PT 10 HD.
Maybe my HDX cable to the HD IO is messed. Its a long one - 25'
Old 07-15-2013, 04:04 PM
mykhal c's Avatar
mykhal c mykhal c is offline
supposed to be no longer than 6ft, i thought...definitely could be the cause tho...
bassist...deep pocketz anyone???!!!
The Basschakra Lucid Soul Trip
i7 Builds - Specs and Results
HDNative | Omni | i7-3930K OC'd 4.0GHZ |
ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff
Old 07-15-2013, 04:07 PM
I'd try another cable and another drive. That way we can eliminate those if we still have problems.
Just make a copy to an external FW drive to try.
Park
Audio dropouts at 48k youngas75 Pro Tools 11 2 11-06-2013 09:25 AM
Audio Dropouts in PT 8 sricabla 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-10-2010 07:12 AM
audio dropouts 2000mpc General Discussion 1 07-09-2010 02:18 PM
Audio Dropouts on Playback barstool719 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-02-2008 12:59 AM
Audio dropouts help YUL Digidesign Hardware & Software 0 11-13-2001 09:06 AM
