Ungroup Clips Shortcut Not Working?
Win7 64 PT10 w/CPTK
Don't use Region (Clip!) Groups all that often but I've got some big BV's I'm working on so have been using groups a lot the last couple of days. Ctrl-Alt-G works fine to group them but Ctrl-Alt-U doesn't seem to be ungrouping them. Anyone else confirm this or is it just me?! Cheers!
Chaz Shifting Sands Audio www.shiftingsandsaudio.com soundcloud.com/shiftingsands Asus X79 Deluxe | i7 4930K @ 4.1 | 32Gb Ripjaws CL9 GBLZ | Radeon R5 230 | Win7 Pro (64) | 256Gb Samsung 850 SSD | 2x 1Tb Seagate SATA | 250Gb Samsung EVO SSD | 128 Samsung SSD | Antec 650W | ProTools 11.3.2HD, 10.3.9HD, 12.5 | Cubase 9.0.20 Pro | Nuendo 8 | Studio One 3.2 Pro | RME UFX | 2x Octopre Mkii Dynamic | Alphatrack | DTouch | Logitech G510 | Kensington Trackball | Yamaha UX256
Re: Ungroup Clips Shortcut Not Working?
No-one?
Have you solved your problem ?
I'm experiencing the same issue. Also with "import video" (ctrl-alt-i) and "Narrow mix window" (ctrl-alt-m).
Win 10 pro, Asus Rog Maximus, i9 [email protected], 64GB PTHD native, 2x96IO, SSL Delta Link, S3 |
Thanks for replying; no, it's still a broken shortcut for me. Narrow-Mix doesn't work for me either (can't confirm Import Video for you though as I'm not in the studio right now & usually use the menu option for that - sorry).
Downloading 10.0.1 now, no mention of shortcut fixes but we can live in hope I suppose...
I can confirm the Import Video shortcut doesn't work on my system either.
10.0.1 doesn't fix it or the Ungroup clips shortcut for me. However, CTRL-ALT-M for narrow mix now works intermittently - there is a chance it was working intermittently before 10.0.1 however as I very soon got tired of trying it & have just been using the menu option! I suspect the latter is the case!
After trying several keyboards, I finally tried to change keyboard input language to "US" instead of "United States-international" .
(Control Panel -> Region and Language -> Keyboards and Languages tab -> Change Keyboard -> General tab) And... all keyboard shortcuts work fine now Hope it helps you!
Good find - thx! All shortcuts now seem to be working!
Cheers!
Midi Clips View Problem, option + "-" keyboard shortcut broken | kingtinker | Pro Tools 10 | 5 | 09-25-2016 01:47 PM |
is there a shortcut for seperate and mute clips at the same time | evilstudios | Pro Tools 10 | 0 | 11-24-2013 06:22 PM |
Select unused clips - Key command not working? | ronwasserman | Pro Tools 11 | 5 | 06-21-2013 11:48 PM |
Clear selected clips shortcut not working hd 10.3.2 | dgoodi22 | macOS | 7 | 02-08-2013 04:49 PM |
Plugins only working for parts of track (certain clips) | Jackmcollins | macOS | 2 | 01-02-2013 11:45 AM |
