Plugin Automation Suspend
Hi there!!
So basically I have a project in which I have to do some EQ work on each region. I select the region, suspend, tweak the EQ and then Write to all Enable. So that for me works fine. My question is: in order to tweak the EQ on that track, I need to be on the suspend mode. What if on track number two I have already tweaked another region that plays at the same time? My problem is that I can't hear the final result of my tweaked region on track number 2 whilst I tweak the region on track number one to get a similar sound. With suspend mode on I'm not listening to the other plugins' work. Is there any way I could do this? Thank you very much! |
Re: Plugin Automation Suspend
Preview automation
-Ryan Young •2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Put the track you wish to tweak into touch, then turn on preview, tweak away then hit write to all enabled.
At least that's how I do it, there are probably many ways to skin this particular cat.
PT Ultimate 2021.3 | macOS 10.15.7 | Mac Pro 7,1 michaelfbates.com imdb.com/name/nm4876413 |
I do this by using Preview Mode also. I always have my tracks in Touch/Latch so I just get the setting I want on the plug in and either Write To Selection or Write To End, whatever I need.
Now if Avid would let us have a Preview All Except Volume... Last edited by reidj; 08-20-2018 at 07:29 AM. |
'Suspend Automation' enabled, resets all my plugin settings! | GuitarGiddz | macOS | 8 | 08-24-2020 07:54 AM |
Suspend automation | lindellsound | Pro Tools 11 | 3 | 12-08-2015 04:47 PM |
Suspend automation issue | ianfleming1992 | Pro Tools 11 | 5 | 02-08-2015 12:50 AM |
Use of Suspend Automation | ramu745 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-15-2009 08:18 AM |
Suspend Automation Playback for some but not all | Don Geppert | Pro Tools TDM Systems (Mac) | 3 | 02-16-2006 04:31 PM |
