Old 11-11-2013, 07:33 PM
rob gracia stone rob gracia stone is offline
Default pro tools 8 le quits unexpectedly while changing from file to file.
Im trying to change from file to file and I keep getting the unexpectedly quit window. It lets me save the session or file and once i press save it closes and then I get that unexpected window. I have not added any new plug ins or other software. Anyone else having that problem?
Old 11-12-2013, 01:09 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: pro tools 8 le quits unexpectedly while changing from file to file.
Are you saying it crashes when you press save?
Or is it when you either close the session or open a new session?
You can view the crash logs.... User / Library / logs / crash reporter. The crash report should say which thread caused the crash and by viewing the crashed thread it might reveal the cause etc. you could copy paste the crash log here in the forum?
What operating system are you on?
Chris
Producer, Engineer,
www.ukmastering.com
Pro Tools 9 wont start! Quits unexpectedly.... Quits during startup... dbC4G Pro Tools 9 11 03-09-2012 07:23 AM
PT10 unexpectedly quits when changing buffer propower Pro Tools 10 2 11-22-2011 09:27 AM
Pro Tools 9.0.5 quits unexpectedly shari 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-07-2011 02:22 AM
Pro tools quits unexpectedly moiblest3 Pro Tools TDM Systems (Mac) 15 03-31-2009 11:09 AM
Pro Tools quits unexpectedly nunuk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-03-2007 06:55 AM
