Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Mac)
Old 07-23-2013, 03:49 PM
Anderson27 Anderson27 is offline
Default "Hardware Not Found" Mbox mini 3rd gen
I just got this problem today. I searched the forums and found that this seems to be a common problem with this unit. More on Windows machines from what I have read. I have un/installed the drivers several times. Current ver is 1.1.3 just installed 1.1.4 with no results so I am back at square one.
System: Mac Pro OSX 10.7.5, 2.8 Ghz Quad Core Intel Xeon, 16 GB Ram, (4) 1 TB Drives, Mbox mini 3rd gen, Pro Tools Express.
Can someone please help me? Thanks
File Type: png Screen Shot 2013-07-23 at 6.42.47 PM.png (75.0 KB, 0 views)
Old 07-24-2013, 04:08 AM
anz anz is offline
Default Re: "Hardware Not Found" Mbox mini 3rd gen
Where did you get 1.1.4 from? Most recent Mac driver version available at download page is 1.1.3: http://avid.force.com/pkb/articles/e...nload/en374271. Are you sure that you downloaded drivers exactly for MBox mini (not MBox or MBox Pro)?
Old 07-24-2013, 08:00 AM
I think I did the 1.1.4 on accident. Since my post, I have done a new install of everything as if I just opened the box. Changed cable, used all of the 6 usb ports and still nothing. The light will come on but when launching software the same "hardware not found" error still shows up.
Old 08-01-2013, 08:22 AM
h77mack h77mack is offline
Hello everyone!! I see that everyone is having similar problems. I to have the mbox mini. I installed it and used it between PT Express and another DAW from may to july with no problems. I disconnected everything and took it to another studio and had no problem. All of a sudden, when i started everything up a couple of days ago, i got the "hardware not found" error. I've done the same thing that everyone else has done with uninstalling and re-installing drivers with no success. After reading i have not seen a solution to the problem. What i don't understand is that it worked fine for a couple of months, but now i get nothing but the blue light indicating that it is connected but not!!!
Please Help!!!!!
15-inch, Mid 2012
Processor 2.3 GHz Intel Core i7
Memory 4 GB 1600 MHz DDR3
Software OS X 10.8.4 Mountain Lion
Hassan Mack
Producer/Partner
Old 08-01-2013, 09:14 AM
[QUOTE=h77mack;2068890]Hello everyone!! I see that everyone is having similar problems. I to have the mbox mini. I installed it and used it between PT Express and another DAW from may to july with no problems. I disconnected everything and took it to another studio and had no problem. All of a sudden, when i started everything up a couple of days ago, i got the "hardware not found" error. I've done the same thing that everyone else has done with uninstalling and re-installing drivers with no success. After reading i have not seen a solution to the problem. What i don't understand is that it worked fine for a couple of months, but now i get nothing but the blue light indicating that it is connected but not!!!
Please Help!!!!!
15-inch, Mid 2012
Software OS X 10.8.4 Mountain Lion[/QUO
After going through the forum, I originally thought it was only a Windows problem. It also seems as if Avid has not come up with a fix for this problem and just decided to release different hardware!
Old 08-20-2013, 06:47 AM
popajoe popajoe is offline
http://duc.avid.com/showthread.php?t=341449
Old 09-15-2013, 05:51 AM
Nisser Nisser is offline
Hi ,
Just want to join the group of people with "hardware not connected"
I recently purchased Pro Tolls Express with the M-Box Mini.
I followed the instructions and all went well - Pro Tools started and the sound came out through the M-Box.
I installed the programs on my new Mac Mini. Pro Tools soon prompted me, that I needed more CPU power, so I installed 16 GB and restarted.
Still all went well - Pro Tools and M-Box were running - joy…
As I had to move to a new address, I packed everything down and haven't tried to use Pro Tools or M-Box until now.
BUT now as the M-box control window appears it says: hardware not connected - not streaming.
The M-Box has power (the light is on) and I have tried with another USB cable - no luck.
I have tried to un-install M-Box, and then tried to re-install it.
As I have re-installed it, I have remembered to unplug the USB before installing.
I have found 4 different drivers on your homepage:
MboxMini_1_1_2_OSX_77731.dmg
Mbox_Mini_1_1_3_Driver_Mac_78311.dmg
Mbox_Mini_Drivers_v107_72735.dmg
Mbox_Mini_Drivers_v105_68826.dmg
I have tried to install them one at a time - each time restarting the Mac - and every time I am told that the installation is successful?
I have tried to connect the M-Box after each driver install - but no luck.
Any help appreciated - but as far as I can see, nobody has found a solution.
Is it time to join forces and give AVID some kind of wake up call??
They are apparently selling a product that doesn't work.
System:
Mac OS X, version 10.7.5
Processor 2.3 Ghz Intel Core i5
Memory 16 GB 1333 MHz DDR3
Software Mac OS X Lion 10.7.5 (11G63)
Old 09-20-2013, 12:50 AM
PKP PKP is offline
I have this problem too this morning.
Hardware not found. Blue light still on.
10.7.5
iMac 2008 2.8 GHz Intel Core 2 Duo
Pro tools 10
Yesterday it was working. Now it is not!
Repaired permissions. uninstall, install.....
Avid, please find a solution!
File Type: png Kuvankaappaus 2013-9-20 kello 10.49.54.png (93.3 KB, 0 views)
Mac Pro 2.66GHz 8GB 10.6.2 PTLE 8.0.3
Old 09-20-2013, 03:20 AM
10.7.5
Pro tools 10
Hi PKP,
Sorry to hear yo've got the same problems - let's keep an eye on this thread and see if anymore people turn up with the same issue - maybe we can do something about contacting avid together.
best
nisser
Old 09-20-2013, 06:18 AM
PKP PKP is offline
This is really strange. It was working ok just yesterday.
Is Avid reading these forums? or how should I contact who??
Please post here if you find a solution.
PT10/Mbox Mini "Unable to locate hardware..." portrhombus Windows 3 12-21-2012 07:47 AM
Mbox Mini 3 - "Unable to locate hardware" Platy Windows 0 02-06-2012 08:16 AM
Mbox Mini Lights up but "hardware not found" gramtsupak 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 19 12-05-2011 09:07 PM
Yet ANOTHER Mbox 3 Mini "Unable to Locate Hardware" Wayne_brady 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 06-14-2011 02:52 PM
Mbox mini installation problem - "Hardware Not Found" tinsoldierman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 12-18-2010 03:06 AM
