Old 02-08-2012, 01:37 AM
David Lang David Lang is offline
Default Re: Protools 10 Rewire Client
Hi Greg,
I now believe this is a Reason 6 issue. I did another clean install, PT10 with Reason 4.01 and Reaper 4.5. Rewire is now fine and working smoothly as before. However, it would be good to get Reason 6 to work. I'm a bit confused by the /32 switch on the install command line. Since I'm running Windows 7 32-bit, would this not force a 32-bit install anyway?
Many thanks,
David
Old 02-08-2012, 09:15 AM
Greg M Greg M is offline
David,
You certainly would think that running Win 7 32 bit that Reason 6 would be smart enough to load the 32 bit version, But, I'm not sure that's the case. I'm running Win 7 x64 and have no trouble Rewiring Reason 6.02 to PTHD 10. But, I did have to go through the process of creating an installation shortcut and adding the modifier ( /32) to the target line to get the 32 bit version of Reason to install.
I guess one way to tell if you have Reason 32 bit loaded is to look at the desktop shortcut icon. It will say "Reason (32)" under the icon. The 64 bit version just says "Reason" under the icon.
My advice is that you uninstall and then follow the procedure I listed in my post above.
Hope this helps,
Greg
Protools PC, i9 10990, Gigabyte X299 mobo, 64 GB ram, EVGA Nvidea GT 720 TI video card, Win 10 Pro, PT Ultimate (Native) 2024.3.1, HD Omni, HD I/O 16x16 .
Sibelius First don't appear in Protools as Rewire Client Christiansyn Windows 10 03-03-2013 06:32 AM
Axiom Pro & ReWire Client Ableton Live filosofem MIDI 1 03-11-2010 12:45 PM
BFD lite ReWire Client? tiotever Virtual Instruments 3 02-01-2010 04:03 AM
best/favorite rewire client for adding trax??? mykhal c 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 07-01-2008 09:57 AM
Project 5 as Rewire Client in ProTools - No Worky CassidyGT 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-15-2005 08:05 AM
