Old 01-31-2011, 11:20 AM
Pompolius Pompolius is offline
Default DAE error -9126
I have some problems with my system. I use a MacBook with Pro Tools LE 8.0.4cs2 running and a Mbox 2. All of a sudden, when i try to open my sessions i get the error -9126. What does that mean?
I cant open any of my sessions. I need help :) Thanks!
Old 01-31-2011, 11:41 AM
plastikman plastikman is offline
Default Re: DAE error -9126
9126 generally associated with hard drive problem. Are you using an external HD for recording? What kind of drive are you using? What kind of connection (firewire, usb, sata)? What format is the drive?
Old 02-01-2011, 08:25 AM
I'm using a LaCie Hard Disk 1TB with USB 2.0. It's formatted as Mac OS Extended (Case-sensitive, Journaled).
Could it be the problem that it's Case-sensitive? Should it just be Journaled?
Old 02-01-2011, 09:32 AM
You should not use a Case Sensitive format, Mac OS Extended (Journaled) is what you should use. You also should not be connecting the Lacie via USB. Use Firewire, or eSATA if you have the option.
Old 02-01-2011, 10:36 AM
Thank you, it works smooth now. Can i work Time Machine on my external harddrive now or will it just [bleep][bleep][bleep][bleep] up again?
Thanks again one more time!
Old 02-01-2011, 12:05 PM
Your welcome, glad it's working. No, you should not use Time Machine on your external.
http://avid.custkb.com/avid/app/self...e_Time_Machine
DAE Error -9126 Parches Pro Tools TDM Systems (Mac) 1 02-10-2012 09:56 AM
DAE error 9126 Kornfed Records Pro Tools 9 10 08-06-2011 06:57 AM
PT9 DAE error -9126 bigtuna macOS 1 07-21-2011 03:30 PM
Error -9126 pinguman Pro Tools M-Powered (Mac) 2 10-25-2010 11:56 AM
DAE error -9126 Oldskewl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-03-2010 06:39 PM
