Old 03-01-2007, 08:45 AM
otravox otravox is offline
Default Migrating LE6 (pts) to LE 7 (ptf)
I just upgraded my system from LE6 to LE 7
and have a lot of material that I am transfering over.
What issues can I expect from the old .PTS files
that I will be opening in LE 7?
I'm aware that the plug-ins may not be there,
but are there other things that don't
translate well going 6 to 7?
Also, if I wanted to use the .PTF files created
in LE 7, how would I open it in LE 6?
Old 03-01-2007, 04:03 PM
SonicAlbert SonicAlbert is offline
Default Re: Migrating LE6 (pts) to LE 7 (ptf)
I regularily open files from PT 5.1 from my brother in PT 7.3 with no problems whatsoever. I suspect going from v.6 to v.7 would be just as smooth. I've been extremely pleased how well PT handles opening old files.
I fyou are goin backwards from version 7 to an earlier version you have to use the menu item "Sav File In..." and choose "5.1 to 6.9". I've never done that, so I can't say how well it works or not. But I suspect once you start using version 7 you won't want to go back unless you need to in order to send a session to someone with an older version of PT.
Migrating fm PC -> Mac CrazyFingers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-16-2010 12:52 PM
Migrating PT8 HD to PC ammusicco Pro Tools TDM Systems (Mac) 13 09-20-2009 07:10 PM
Upgrading from LE to HD and migrating OS - best way to do it fm_xtk Pro Tools TDM Systems (Mac) 3 01-04-2009 10:38 AM
Migrating to Mac from PC... Wheeltard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-11-2006 12:16 AM
migrating from a g4 to a g5 willbgoode Pro Tools TDM Systems (Mac) 0 10-05-2004 06:36 AM
