Old 02-20-2007, 10:16 AM
Johnny Cadelco Johnny Cadelco is offline
Default Noise after bouncing to AIFF
Hey guys, i tried searching for this topic but didn't find anything. Anways, I generally do all my mixes and they sound good while i'm mixing it. I always leave room enough for it not clip at all, at -3db. But when i bounce to aiff file stereo interleaved i get alot of noise especially when the bass comes. Remember i get no clipping at all not even near. So what's the problem? what should i do to fix this..
Old 02-20-2007, 11:02 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Noise after bouncing to AIFF
I would start with the troubleshooting thread...
http://duc.digidesign.com/showflat.p...fpart=1#177661
And also check you mix levels with the metering set to pre fader and post fader, just to double check your levels when bouncing!
And your master fader is set to default 0.0
Chris
Producer, Engineer,
www.ukmastering.com
Old 02-20-2007, 11:24 AM
my fader is set to 0.0.. and how do i set my metering level to prefader like u said?
Usually i can tell if it clips, but there's no clipping because the master fader would indicate after it bounces. im sure 100% sure it has to be something else...
Basically the only i have is a compression on the master. I use dynamics 3 compressor, u think this would cause it?
Old 02-20-2007, 12:08 PM
blackmacdaddy blackmacdaddy is offline
1. Double check that none of your sends are clipping internally. Under
view you can select 'assignments' to see the mini faders and look for
clipping on a pass. If you've used many different sends, you could also
use the 'target' to view different (a-j) sends at once to save time.
2. I've recently had strange noises when using the DIGI MED delay plug
(a crackily, almost 'shorting out' sound) It looks like you're not using
too many plugs. In my situation, what is bizarre is that a track can be
'pristine' and then a few minutes later, it's all distorted. Removing the
DIGIRACK delay plug inserting a different plug makes the noise go away.
It's only R'n'R but I like it.
Bouncing AIFF and mp3 at the same time. Polarbear066 Pro Tools 11 2 10-13-2013 01:07 AM
BOUNCING AIFF 44.1 16bit HELP... DLinares 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-20-2007 09:36 AM
bouncing to mp3 or aiff plasticefx1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-10-2006 08:57 AM
Bouncing to disk problems (wav, aiff-c, mp3, aiff) TinglerFran 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-30-2003 11:38 PM
Bouncing to AIFF Nails 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-03-2001 12:17 AM
