before I buy a new LCD, will this original card work
I have an ATY,RV250, which I believe refers to an ATI Radeon 9000 Pro video card. It is original with the computer.
I want to get an LCD, probably 22 inch - will this video card work with a this new 22" LCD or cause problems? - considering I'd also like to get a new monitor for photography as well as for pro tools, is there a better recommended video card to buy? Power mac G4 tower/1.25 Ghz single processor/2Gb ddr SDRam/ Machine Model: Power Mac G4 CPU Type: PowerPC G4 (3.3) Number Of CPUs: 1 CPU Speed: 1.25 GHz L2 Cache (per CPU): 256 KB L3 Cache (per CPU): 1 MB Memory: 2 GB Bus Speed: 167 MHz Boot ROM Version: 4.4.8f2 Serial Number: XB41500XPC4 |
Re: before I buy a new LCD, will this original card work
I do not suppose it would cause any problems, the only point will be the resolution you want to use for the 22" LCD...
1024 x768? Should not be a problem... 1280 x 1024? Should not be a problem... 1200 x 1600 or larger? I don't know for sure, but one of my G4's with a stock ATI Radeon 9000 Pro does it without a hitch with 2 x 20" LCD's connected...
Marc Schellekens Delta Music Belgium - Dolby Atmos Music Studio https://www.deltamusic.be Mac Pro 2019 - 3.2GHz 16-core - 96GB RAM - macOS 14.4.1 - PT HDX3 - Pro Tools Ultimate 2024.3.1 - Avid HD I/O 16x16 (x2) - Avid HD I/O 16x16 Digital - Digidesign 192 I/O - Digidesign 192D I/O (x3) - Avid SYNC HD - Apogee Big Ben - Apogee Rosetta 200 - Avid S3 - Slate RAVEN MTi2 (x2) - iConnectivity mioXL (x4) - Genelec ‘The Ones’ 9.1.6 Dolby Atmos Music monitoring (AES/EBU) with 8341A (x5) + 8331A (x10) + 7360A (x2) + 9301B - Almost all available AAX-DSP plug-ins |
thanks for the reply Marc, that gives me more confidence
my card goes as high as 1280 x 1024 |
It is possible that the driver for the video card is not up to date enough to handle the resolution of the newer wide screen monitors. A 22" wide has a native resolution of 1680 x 1050, so if your driver doesn't support that mode, you would be better off with some other solution.
It is possible that the driver is recent enough or that you could get a new enough one, but your older hardware is going to make that difficult. I'm guessing that the only new video card you can get for PCI mac these days is this one: (if your G4 has AGP video then I don't know what might be available) http://eshop.macsales.com/item/ATI%2...ies/100436014/ But at the bottom of the page, 1680x1050 is not listed.. It is possible their list is not complete, but you are venturing into difficult territory... I would suggest that you confirm what resolutions are supported by your current video card, or the above PCI card, and then plan your monitor choice around that. LCD monitors look like crap when you run them at non-native resolution IMO
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
Will my Original MBox work with Protools 8?? | mberger79 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 04-29-2017 03:06 PM |
AVID HDX PCIe CARD FOR PRO TOOLS HD10 & HD11 BRAND NEW IN SEALED ORIGINAL BOX | Beatstreet | Buy & Sell | 0 | 11-26-2013 03:57 PM |
will pro tools 9 work on original Mbox interface | bissodj | Pro Tools 9 | 17 | 03-01-2012 09:56 PM |
Any way to make the original O2R work with PT 7.3? ANY WAY? | rockumro | Pro Tools TDM Systems (Mac) | 7 | 06-18-2007 12:33 PM |
re: VIDEO CAPTURE, Fuse card is approved but will Igniter card work as well? | ragbor | Pro Tools TDM Systems (Mac) | 0 | 12-08-2000 11:56 AM |
