Pro Tools 11 Update Playback Engine Problem
Did the update to Pro Tools 11.1 and now when I try and load a 48Khz session I get the "The Current playback engine does not support a sample rate of 44.1 KHz" when I load a 44.1 KHz session I get the same message. IM on a PC, Windows 7 SP1, Audio Interface AVIS FastTrack C600. Tries to change the sample rate in C600 interface its set still does not work, went o Control panel set the default sound machine still does not work?
Producer/Engineer/Musician RIAA Platinum Sales Award: Lisa Stansfield "Affection" Main: Model: Dell 5750 Precision Workstation OS: Windows 11 Pro 64bit CPU:*Intel Core Processor i7-10750H (6 Core, 12MB Cache, 2.60 GHz to 5.00 GHz, Memory:64GB, 2X32GB,DDR4 2933Mhz Non-ECC OS M.2 512GB PCIe NVMe, Record Intel 1TB SSD, 2T SSD, 1TB SSD Focusrite Scarlett 18i20 3rd Gen AVID Pro Tools 2023.12 JBL LSR4328P 8" JBL LSR310S 10 inch Powered Studio Subwoofer* Yamaha HS50M Studio Monitors Alesis Elevate 3 Studio Monitors M-Audio Axiom 61 Midi Controller |
Re: Pro Tools 11 Update Playback Engine Problem
Did you restart after changing the Windows default playback device to something other than the fast track?
Did you also set the Windows default recording device to something other than the fast track? |
I have set the engine and restarted still does not work, IM not sure I didnt do anything but uninstall 11.0.2 and install 11.1.0 and the whole audio engine changed, it worked before? I need a Control Panel> Sounds> etc, etc, walk thru to set it.
Thank you mesaone for the help, That worked, I kinda knew what I needed to do just didnt know all the steps... Problem Solved...
Playback Engine Problem | mrussaustin | Pro Tools SE and Essential (Mac) | 0 | 10-11-2012 05:09 AM |
PT 9.0.5 Native has problem with playback engine | JoeM | Pro Tools HDX & HD Native Systems (Mac) | 2 | 12-04-2011 06:08 AM |
Playback engine support problem... | jjtarnow | Pro Tools M-Powered (Mac) | 0 | 01-09-2011 11:18 AM |
Playback Engine Setup Problem in PT 7.4.2 | MattCraft | Pro Tools TDM Systems (Mac) | 1 | 07-07-2010 01:47 PM |
MTC sync / playback engine problem | Ulrich Reiter | Pro Tools TDM Systems (Mac) | 1 | 02-22-2002 06:49 AM |
