Wrapper for VST3
In my studio, I use the Motif XS8 as my main controller with PT. Yamaha has recently announced they are about to release a VST editor for the Motif XS. It will be built on the VST3 format and will allow you to edit sounds on the keyboard from with your DAW.
What I'm wondering is whether or not this might work with the VST wrapper for PT? Here's a description of the software: What is the MOTIF XS Editor VST? MOTIF XS Editor VST is a convenient tool which lets you edit and save the various parameters of your MOTIF XS tone generator. These include Voice and Mixing parameters (edited in the Voice or Mixing mode of the MOTIF XS) such as Volume, Pan, EG, and Cutoff and other settings. Thanks to its easy-to-understand graphical interface, you can edit various parameters of the MOTIF XS right from your computer—using the mouse to adjust the virtual knobs, sliders, and buttons and entering values from the computer keyboard. Finally, all the changes you have made can be saved to your computer or transmitted to the MOTIF XS instrument. The MOTIF XS Editor VST, based on the “VST3 technology” by Steinberg, works as a VST3 plug-in with Cubase series 4.5 or later (DAW application). The MOTIF XS Editor VST also works as the same way as other VST instrument software, allowing you to save the edited settings of the MOTIF XS, or use them for another project. In addition, you can handle the MOTIF XS Voices in the Media Bay window in Cubase when using the MOTIF XS Editor VST with Cubase 4.5 or later, allowing you to search for, listen, and play the MOTIF XS Voices within Media Bay in Cubase. The MOTIF XS Editor VST provides a comprehensive and seamless music production environment—making the use of hardware and software both easier and much more efficient. |
Re: Wrapper for VST3
The FXPansion wrapper doesn't do VST3
They also haven't updated it since 2006 (even then they forgot to change the version number)
@theaudiogeek | www.EPICSounds.ca | www.AudioGeekZine.com | www.HomeRecordingShow.com | |
I can't help but think how cool it would be to be able to access the Motif editor within PT and tweak on the fly as tracks are playing! |
VST3 wrap or workaround? | Wasaia | Tips & Tricks | 4 | 11-17-2008 04:12 PM |
VST Wrapper | danika | Pro Tools M-Powered (Win) | 1 | 07-30-2005 07:52 PM |
VST Wrapper | gtruno | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 07-22-2005 07:38 PM |
vst/wrapper | PlainJoe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 10-15-2004 04:45 AM |
VST Wrapper | 1Angelo1 | Pro Tools TDM Systems (Win) | 5 | 12-15-2003 01:52 PM |
