Old 07-22-2012, 09:21 AM
eneezy1 eneezy1 is offline
Default Midi Controllers - Midi Port Assignment
MBox Pro
OS X - 10.7.3
Pro Tools - 9.0.5
MPK49 (Controller / Keys)
Maschine (Controller - Percussion Pad)
I'm assuming the reason I can't switch signal input from one controller to another is because of the way my midi ports are set up, is this correct? Right now I can only get signal input (from my Maschiine pad) using my MPK controller. Do I need to switch midi ports around so I can get signal input from Maschine directly into PT? More ideally, how can I get signal input from both of these controllers? My current midi port assignment is:
MPK49, Port 1
MPK49, Port 2
MPK49, Port 3
Maschine Controller, Midi input port 0
Also, even when I assign the Maschine controller using the I/O assignment in the Mix window, I still cannot get signal input directly into PT (without going through the MPK). Any thoughts here? Thanks for your help!
-E
Old 07-22-2012, 06:01 PM
Default Re: Midi Controllers - Midi Port Assignment
Route both devices via USB MIDI and assign in Pro Tools Instrument Track MIDI I/O selectors.
Aaron Mulqueen - 001 HD Native
Old 07-24-2012, 12:34 PM
Will give it a shot. Thx.
Old 07-29-2012, 01:05 PM
I was able to select Maschine in the mix window (under insert) and am now getting an input signal, but then when I record, the signal does not get recorded. I tried to select Maschine as my input (under I/O), but it was greyed out under my plug-in list / menu. Any next steps to get this to the point where I can actually record the signal? Thx.
Old 07-30-2012, 02:40 PM
Not sure, start a new thread with 'Maschine' in the heading and I'm sure someone with this device can assist.
Midi Predifined options in Peripherals\Midi Controllers menu RuffinMedia macOS 3 03-04-2015 04:54 PM
MIDI CC Assignment Table in Pro Tools AMIEL MIDI 5 10-14-2013 12:12 AM
MIDI Virtual Ports not showing up in MIDI Controllers (8.0.5) emiliojazz Pro Tools M-Powered (Mac) 0 02-18-2013 12:03 PM
Midi Controllers - Midi Port Assignment eneezy1 Pro Tools M-Powered (Mac) 1 08-15-2012 08:44 PM
Virtual MIDI port and legacy controllers aronnelson Pro Tools TDM Systems (Mac) 0 02-08-2010 01:47 PM
