How To Use Pro Tools Offline
How do I use Pro Tools offline? When I load up the program and am not connected to the internet I get a message informing me that I need to connect to the internet in order to proceed, and when I click OK the program shuts down. Any help would be greatly appreciated.
Last edited by jeffro; 12-21-2018 at 09:27 PM. Reason: PT 18.10.0.246 - thread moved from PT12 section |
Re: How To Use Pro Tools Offline
Is this the free PT First version or a full PT12 as you posted in the PT12 section?
This is the full PT12.
Then you must have been trying to open a cloud session which requires an internet connection also called a project I believe.
Start a new session where you set your harddrive as the session target for the recording. Make sure it isnt set to project or cloud session.
Thank you Southsidemusic. I'm doing some audio editing on a session that has already been recorded. Is it possible to change that setting on an existing file?
Is it a Session (local) or a Project (cloud)? Internet is required to create a Project (cloud session) but after creation, a local copy is cached so you can work on that without an internet connection. Might help to know the exact message you're getting as well as the exact version of PT you have installed. Can you please reply with screenshots?
linkedin
I attached a screenshot, thanks for the help
Thanks for the screenshot of the error.
linkedin
iLok Licence Manager closed on me , I believe because I dont have my Mac connected to the internet so I couldnt close the cloud session. Does having an internet connection transfer data when Im using Pro tools? I can maintain a connection but I cant pay for constant data transferring. I would need to disable cloud backup which I dont use anyway but I dont know how to do that.
Again what version of anything do you actually have? Are you asking about Pro Tools or Pro Tools First? Pro Tools First only support cloud based projects. Pro Tools support projects or sessions. More explanation is in the Pro Tools reference Guide. You are posting in the Pro Tools 12 forum section. Are you really using Pro Tools 12, what exact version? (not all support cloud sessions) First 2018? Ultimate 2018? You said earlier you are using Pro Tools 12 but Jeffro did not see that associated with your account. So do you have multiple different Avid or iLok accounts? If you choose to work in a cloud project then obviously it uses the internet as you work. If you work on a local session, with an iLok then the internet is not involved. If you choose to use a cloud licensing then it communicates a small amount of data as you are working to support licensing. Your choice to do that or use an iLok. You have to work out how to close the cloud project and get yourself set up properly. There are a pile of stuff in the Pro Tools Reference Guide and online FAQs and other information on Avid's web site you can search through that explains all this stuff and more. Including this https://avid.secure.force.com/pkb/ar...laboration-FAQ |
Command|8 (Offline) with Pro Tools 10 | tj2toxic | ProControl, Control|24, Command|8 | 8 | 05-30-2016 10:11 AM |
Pro Tools 12 HD offline bounce bug | bad jitter | Post - Surround - Video | 0 | 05-06-2016 08:12 AM |
Pro Tools 12 HD offline bounce bug? | bad jitter | Pro Tools 12 | 1 | 05-05-2016 11:31 AM |
Command|8 (Offline) with Pro Tools 10 | tj2toxic | Windows | 1 | 11-30-2011 05:14 PM |
Pro Tools freezing and C/24 offline | brewcity1 | ICON & C|24 | 1 | 12-01-2008 10:29 AM |
