Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
Old 11-07-2018, 03:24 AM
zavid zavid is offline
Default Laptop Daw Win 7 Advices Welcome
Need to set a Laptop Win 7 mobile Daw for Live sessions recording
any advice/help about is Welcome
thanks
Old 11-07-2018, 11:30 AM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
Default Re: Laptop Daw Win 7 Advices Welcome
So Win 7 is not supported after PT 12. something(5 maybe?) so the only way to get it to work is to install the version that is supported and application manager to update through to get to latest version(if you try to install 18.xxx directly without AppMan it will give you an upgrade OS error and wont install). If you can possibly find something with a dual hard drive setup you will have better operation. It kinda goes without saying that SSD are more or less required, especially if you are trying to record to a single drive. The fastest non turbo/overclocked processor and most memory(8 gig sorta works 16 is good, more would be best but its hard to find a laptop chipset that will run more than 16. A good fan for the processor ventialtion (since optimization will have you shut off the processor sleep its going to run hotter)You might check the build threads for links to pro builders and their recommendations , etc. I have two laptops running Win 7 and PT 2018.10 so it can be done. They do have limitations though so dont expect them to live up to desktop performance.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
Old 11-07-2018, 11:44 AM
much thanks for the post !
mainly i have to record live sessions ,
not many plug ins are required , not to have to do F.O.H. (fortunately )
i have the "resident" daw based on win 7 with many other apps
(audio , video , etc….)
as i know it well (for better and for worse)
i do not have much time to spend / waste
for fix problems……
just need good advice about a good laptop model ,
more thanks for any info about
Going from 10.8.4 to 10.8.5 OSX advices flautista Pro Tools 11 8 01-24-2014 04:07 AM
Advices on PC Rig Mateus Borges Windows 8 03-07-2013 07:00 PM
I need some advices ... Julien Apruzzese Pro Tools TDM Systems (Mac) 2 12-07-2006 07:33 PM
I need some advices ... Julien Apruzzese Pro Tools TDM Systems (Mac) 0 12-07-2006 01:33 PM
SSL advices daish Tips & Tricks 17 11-05-2002 12:36 AM
