Old 02-10-2004, 10:46 AM
BuddySchaub BuddySchaub is offline
Default sample rate mismatch with HD24 on whole session
I recorded a whole session with my Alesis ADAT HD24 set at 48k and the internal clock on my digi 001 is at 44.1k. It played back at the right speed the whole session because my Alesis was running, but when I went to bounce the mixed tracks the AIFF files are playing slow. It even sounded fine during the playback of the bounce. Is there any way to change the internal clock on my digi001 or is there another solution to fix the mismatched sample rates?
Old 02-10-2004, 12:53 PM
cabuford cabuford is offline
Default Re: sample rate mismatch with HD24 on whole session
I did this the first time I multitracked with my 001.
I think my solution was to create a new session at 48Khz. Then I imported all the audio files, which PT has tagged as 44.1 but are really 48. It'll give a "audio may play back at wrong speed" warning. But it ends up playing them at the right speed.
This was a while back, but i think it all worked out fine.
QS G4 Powerlogix Dual 1.6Ghz 1.5GB RAM
Digi001 10.3.9 PT 6.4
Powerbook 1.5GHz 1.25GB RAM
Sample Rate Mismatch! (clock 44.1, PT 48) RhodesB3 Pro Tools TDM Systems (Mac) 22 11-24-2015 12:17 PM
sample rate mismatch problem? Kevin_28 Pro Tools 9 4 12-22-2010 11:18 PM
Sample Rate Mismatch... How to export files as regions after problem. Dizzi45Z Pro Tools TDM Systems (Mac) 2 04-24-2010 10:17 PM
Big Ben / PT sample rate mismatch zakco Pro Tools TDM Systems (Mac) 2 10-27-2007 06:36 PM
Pro Tools LE Sample Rate Mismatch Nag tcassel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-20-2007 12:51 PM
