Old 03-21-2024, 11:45 AM
MixerGuy MixerGuy is offline
Default HDX card may be stopping MacPro (2021) starting up. Ventura OS.
Hi all
I have a strong suspicion that my HDX card is stopping MacPro (2021) mid start up. Ventura OS.
Most times (about 80% of the time) - when i try to start up the Mac Pro … I get an apple chime, and small apple logo, and the first part of a progress bar…. but then usually (not always) it kicks over to the Apple recovery option.
A while back (Sept 2023) I initially suspected the MacPro (2021) hardware, so it went to Apple store and the Apple techs there gave it lots of hardware tests…. zero issues starting up.
(it did not have my HDX card in it while it was at Apple)
Apple suggested that possibly some piece of hardware is interrupting the MacPro start up procedure …. and after some time this delay then kicks it over to Apple Recovery Partition.
This issue has been happening on and off since Sept 2023 (now March 2024) but in early Oct 2023 I switched to a Mac Studio Ultra with TB3 chassis on a different HDX card…. so i just havent gotten around to addressing this issue.
The ProTools HD drivers are up to date as of Sept 2023…. and the firmware of HDX cards is also up to date as of Sept 2023.
I have not had time to try a different HDX card in the MacPro… but i am confident that they all have the same firmware on them. (up to date)
yes ILOK software is up to date. i just checked.
Has anyone encountered anything like this before?
thanks!
Old 03-21-2024, 12:46 PM
tope d's Avatar
tope d tope d is offline
Default Re: HDX card may be stopping MacPro (2021) starting up. Ventura OS.
Originally Posted by MixerGuy View Post
Hi all
thanks!
Hi MixerGuy,
I've started a support case for you. It's under case number 04776122. Team will be in touch on this soon.
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 03-21-2024, 05:15 PM
Thank you so much Tope!!! Super appreciated!
BTW Apple was asking me "is there any other hardware connected to the Mac Pro at your studio?" and I explained no, just the HDX card..... and 2 avid interfaces to the HDX card.
Old 03-22-2024, 10:31 AM
but in the meantime... has anyone else encountered this issue?
thanks.
Old 03-23-2024, 11:33 PM
No one?
Old 04-03-2024, 05:09 AM
rickparkhouse rickparkhouse is offline
Yes I am having the same problem - HDX Card in a Sonnet chassis and the computer hangs on the Apple logo every time I boot up with that connected. Works fine if I connect it after boot up but I am having way more random crashes than before which I suspect is linked. I'm on Venture 13.6.4 and a 2019 Intel MBP. HDX driver is up to date. Did you find the solution?
Old 04-03-2024, 11:25 AM
BScout BScout is offline
One or three card chassis.
I've observed issues with the 1 card chassis (whether branded as Sonnet or Avid.) Swapping those to the 3 card chassis and the problem was solved (at the moment, have zero 1 card chassis in use now.)
They use different controller chips and I think there's a problem around the one in the 1 card version.
Old 04-03-2024, 12:54 PM
Thanks for chiming in here... sorry to hear of your issues.
We don't have quite the same issue.. I'm on a MacPro 2019, so my HDX card is IN the Mac Pro, not a chassis of any kind.
and.... Avid is slowly slowly asking questions via support... no clear solution yet...
one thing i randomly discovered was.... if I try to boot and immediately do the old "Zap P Ram" (hold Option Apple PR) and let it re-chime once... then it is MAYBE more likely to then actually boot sucessfully after that.
It only ever gives me one additional chime, not multiple, as expected.
give that a try, and please report back here. Very curious if it works reliably for you! I have not clear info, yet.
Old 04-12-2024, 09:02 AM
aaaannnnnddddddd Avid support has officially dropped the ball... after a couple (slow) back and forth emails....
Old 04-13-2024, 02:15 AM
tonwurm's Avatar
tonwurm tonwurm is offline
not good
MP5,1 12core 3.46ghz 96GB
Ultimate HDX
https://www.youtube.com/channel/UCIA...Rnu0Jfh-YsgftQ
Ventura OS ??? MacPro TrashCan (late 2013) jepmus Pro Tools HDX & HD Native Systems (Mac) 5 03-28-2023 06:17 AM
Loud clicks when starting or stopping playback tnipe Windows 36 06-10-2016 11:58 AM
Starting and Stopping Pro Tools from Venue Scott Fahy VENUE Live Sound Systems 4 02-14-2012 12:43 PM
Cannot control starting and stopping of cursor skydogsound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-03-2008 02:40 AM
display starting and stopping murdock 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-13-2000 09:40 PM
