Old 07-03-2023, 01:15 AM
Default Re: will new Mac Pro M2 Ultra be compatible with current HDX cards ?
Hi Samuel,
here's a video of SMM (German PT studio supplier based in Munich) with HDX3 in an M2 MP.
https://www.youtube.com/watch?v=CpVRImBoA7o
It's in German but they say the NF Sol Levante sessions runs at 30% CPU. They used special cables as the new PCIe slots are further apart than before. Specs of the test in English in the show notes.
Frank.
Old 07-03-2023, 11:12 PM
BScout BScout is offline
The special cables are nothing more than standard SATA cables (shortest length though not critical other than hard to tuck them in when sliding the case down.) I've had a 6 x HDX card setup in a Mac Pro before and that's what those little red interconnect cables are: standard SATA cables.
Old 07-04-2023, 01:29 AM
Samuel Mittelman Samuel Mittelman is offline
Hi Samuel,
Frank.
Hello Frank,
Thank you very much for this encouraging video on the integration of Avid cards in the new Mac Pro.
The machine is arriving this afternoon and I'm starting to install the software and then the hardware...
All the best
Samuel
Old 07-04-2023, 01:33 AM
Originally Posted by pm mastering studio View Post
I just recieved my Mac Pro 2023. It's a beast ;-)
I'm installing all software now and add the HDX card later this week. Installing software goes amazing fast ! way faster than my good old Mac Pro Trashcan ;-)
For HDX Slot 5 should be the one.
I think if you want to add 2 HDX cards you'll need the Belkin AUX power cable kit for Mac Pro. I'll check this out later
Hello Philiippe,
Thank you very much for your message. Have you been able to make any progress with the hardware installation after the software installation? What feedback do you have on this subject?
Thank you
All the best
Samuel
Old 07-16-2023, 11:15 PM
Originally Posted by Samuel Mittelman View Post
Hello Philiippe,
Thank you
All the best
Samuel
The first few days with this new Mac were very enjoyable. Installation went very smoothly and quickly. No problems with HDX cards in slots 5&6.
When you come from a Mac 5.1 it's like night and day, everything is fluid and transparent.
On the other hand, I thought that the latest 2023 versions of protools would work better than on an Intel platform, but I'm just as disappointed.
On a large template, I experience the same slowdown when opening multiple folders and when activating and inactivating tracks. To work, I've installed the good old 2021.12, which works much better than all the latest ones.
Will Avid fix these problems and release a 2023 version that works better with optimised drivers ? The true potential of this machine will be revealed in the coming months with software optimisation and the switch to all-silicon (please Audio Ease, Plugins Alliance, etc. go ahead ! For now, with PT 2021.12, everything's running smoothly. This Mac has a lot of punch and it's a real pleasure to work on it.
Samuel
  #16
Old 07-17-2023, 04:51 AM
Avgerinos Avgerinos is offline
Warm greetings, I just got the HDX card working on my M2 Ultra, but it was quite difficult. My thread is here Mac Pro M2 Ultra & HDX card
King from Avid finished the job over the phone and these are most of the steps:
- DL 2023.3 driver - Launch HD Driver Installer
- Select Uninstall Command
- Follow the Prompts for Uninstallation
- Restart Computer
After Restart
- Install the Driver
- Restart
** *1*** Go to System Preferences > Energy Saver*(on a desktop computer) or System Preferences > Battery (on a laptop) and make sure that Prevent computer from sleeping automatically when the display is off*is checked and that the Turn display off after*slider is set to Never
** *2*** Uncheck Put hard disk to sleep when possible (desktop computer) or Enable power nap*(laptop)
** *3*** Double-click the Install Avid HD Driver.pkg*and follow the onscreen prompts to install the HD Driver
** *4*** When the message System Extension Blocked*appears, click on Open Security Preferences
** *5*** Unlock the setting menu by clicking on the lock icon and typing your password, then click on Allow, and then Restart Now*to rebuild the system extension cache
** *6*** The HD Driver installer, which will still be running, will block the restart and trigger a dialog Installer interrupted restart*- dismiss this*dialog by clicking on Cancel
** *7*** Go back to the HD Driver installer window, wait for it to finish if it hasn't already, then click OK*on the alert requesting you to restart and after that click on the Restart button
** *1*** Restart your Mac in Recovery Mode (see*this article*for instructions)
** *2*** Select Options
** *3*** Select Utilities > Startup Security Utility
** *4*** Select your current Mac system and click Security Policy
** *5*** Select Reduced Security*and check Allow user management of kernel extensions from identified developers
If*your*HDX or HD Native device is not detected, try the following procedure to refresh the system extension cache:
** *1*** Open the Terminal*utility (from Applications/Utilities) and*type:
sudo touch /Library/Extensions
** *2*** Press enter, and enter your password when prompted
** *3*** Restart the computer
If still not detected, check that the hardware itself is recognised in About This Mac > System Information.*The device will still show up even if the HD Driver is not loaded:
** *1*** Hold down the Alt/Option key, click on the Apple icon in the top left corner of the screen, and select System Information...
** *2*** If using HDX or HD Native PCIe, click on Hardware > PCI; if using HD Native Thunderbolt, click on Hardware > Thunderbolt
** *3*** Check that you see either pci11af,ef70 (HDX) or pci11af,ef80 (HD Native/HD Native Thunderbolt) listed
** *4*** If the appropriate device*is*NOT listed, check hardware connections (reseat all cards, cables) and see if any LEDs illuminate on the device. Note that HDX cards additionally require an auxiliary power connector.
Assuming the hardware itself is recognised, next check the status of the DigiDal.kext (HD Driver kernel extension) from the System Information*report:
** *2*** Click on Software > Extensions*and wait for the list to be compiled
** *3*** Scroll down to DigiDal.kext, and check the Loaded*column - if it shows No*the driver has not been loaded and you can try to manually load it*(see below). If it shows Yes*the hardware should be ready to use, and visible as a device in Audio MIDI Setup*(Applications/Utilities). If it is visible there,*but not recognised by*Pro Tools, check that you have valid iLok licenses for Pro Tools Ultimate and Pro Tools DigiLink I/O
To manually load the HD Driver:
** *1*** Download the Avid_Mac_HDDriver_Loader utility
** *2*** Double-click to unzip it, and place the unzipped item in the Applications*folder
** *3*** Launch the utility and follow the onscreen prompts
If the HD Driver successfully loads, but does not load again after a computer restart, you can set the Avid_Mac_HDDriver_Loader to automatically run on login by adding it to System Preferences > Users & Groups > Login Items*(or you can simply launch the utility manually as required).
If the utility is not able to load the HD Driver, an error message should be posted describing the reason why it could not be loaded. In many cases, completely uninstalling the HD Driver (by running the Uninstall HD Driver.command found in the HD Driver installer folder) and then reinstalling*(following the clean install steps) will resolve the issue.
Press and hold the power button until the message "Loading startup options" appears.
A boot picker menu should appear.
Select Options and click Continue to continue into macOS Recovery.
blocked extensions - see antelope article -
https://support.antelopeaudio.com/en...mac-os-ventura
  #17
Old 07-20-2023, 03:37 AM
pm mastering studio's Avatar
pm mastering studio pm mastering studio is online now
Hello Philiippe,
Thank you
All the best
Samuel
I Installed the new beast today with my HDX card in slot 5. Everything works like a charm. Man this thing is fast !
Philippe Meiresonne
(Belgium)
http://www.pm-mastering-studio.com
SYSTEM 1 : Main recording - HDX MAC Pro 2023 M2 Ultra Running Sonoma 14.4
ProTools Ultimate 2024.3.1| 1xHDX Card | Mac Pro M2 Ultra 128Ram 2TB|2x PRE |2x Audient PRE 880| 1x Avid 96 |1x Avid 192 I/O 16/16 Analogue | 1x Avid HD I/0 16/16 Analgue | Avid MTRX Studio + Thunderbolt 3 Interface
Midi I/O | D-Command ES +16 fader Pack | Xmon | Eleven Rack + Dolby Atmos 7.1.4 Surround Adam S3H speaker System
System 2 : Project System - ProTools CARBON Running Sonoma 14.4
MacStudio M2 Ultra |64 GB RAM | ProTools 2024.3 Ultimate/Studio | SSL2+ | AVID S1+DOCK + ProTools|Carbon + ProTools|Carbon PRE
System 3 : Dolby Atmos Renderer Running Sonoma 14.4
MacMini M2 Pro |16 GB RAM | Avid MTRX Studio (Thunderbolt3)
  #18
Old 08-27-2023, 02:44 AM
kingtone kingtone is offline
Originally Posted by MCorbin View Post
I think the risk is low to move forward with your install. We've already done some preliminary and successful testing with Apple, but we've not run it through all the steps to give it an official green light.
m
How close do you think we might be for a green light on these machines?
I check the compatibility grid almost every day in hope.
  #19
Old 08-28-2023, 07:29 AM
MCorbin's Avatar
MCorbin MCorbin is offline
We update the compato grids whenever we do new releases of software. So stay tuned.... also... pro tip... you can Subscribe to a KB article and receive email notifications any time it gets updated.
Mark Corbin
Sr Principal Product Manager
Professional Audio Systems
For immediate assistance:
Pro Tools & Eucon Surfaces - +1 888-456-3444
Venue Support - +1 978-275-2557
Find out how to create, manage, and edit cases online now HERE
It's fast, easy, and effective!
  #20
Old 08-29-2023, 12:30 AM
Good tip on the subscription. Hadn’t seen that option til now. Fingers crossed for some good news soon.
Thanks!
Pro tools 8 compatible with current mac OS Dylan W macOS 14 02-06-2017 12:20 AM
Current HDN/HDX compatible 3rd party i/o's propower Pro Tools HDX & HD Native Systems (Mac) 8 03-18-2016 07:26 PM
PCI Cards from 1 year ago vs. Current PCI Cards i hear dead people Pro Tools TDM Systems (Mac) 1 06-09-2006 06:07 AM
Are SATA and ultra ATA compatible? guy.fi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-23-2005 10:05 PM
SIIG Ultra ATA 100/133 PCI cards 372cat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-04-2003 12:17 AM
