Old 05-08-2023, 08:21 AM
redmount redmount is offline
Default Re: HDX card not showing (Sonnet Echo III Desktop - Mac Studio Ultra)
Originally Posted by Top Jimmy View Post
It seems that others are having the same issue with no clear solution as of yet. Maybe you can go through the support process to further Avid’s awareness of this issue.
https://duc.avid.com/showthread.php?t=423157
Thanks,
but, I have read dozens of posts before buying this Sonnet Echo III Desktop the problem mentioned in the thread you are referring to is when HD native is attached, not HDX ��
Old 05-08-2023, 08:28 AM
Top Jimmy's Avatar
Originally Posted by DetroitT View Post
Recovery mode start and change security to allow driver to load?
James Cadwallader
Old 05-08-2023, 08:29 AM
Top Jimmy's Avatar
Redmount, did you allow security access when it asked you for permission to use the microphone?
James Cadwallader
Old 05-08-2023, 08:41 AM
I did
Old 05-08-2023, 08:45 AM
Still Command + R under Venture / M1 ??
*** sorry, it's a bit of a panic room here !!... restarted holding the power button I guess***
Is it the "Digidal" extension that should load ?
  #16
Old 05-08-2023, 09:04 AM
Recovery mode start done, lowered the "security level" to normal (btw, I translate from my french system to english, so possibly not that accurate)
nothing changes... grrrrr.
  #17
Old 05-08-2023, 11:40 AM
UPDATE :
Looks like i'm on my way to Pro Tools heaven
1- Another attempt of recovery start. This time I have checked both options on the lower security status. This was the best move !
2- after restarting once or twice, System showed the "driver" for the card as installed !
3- I ran a digitest now that the card was visible... Digitest OK
4- a pop up message told me a HDX card firmware update was to be applied
5- restarted again, launched PT, set HDX as a audio engine... restart PT... Was prompted to update the firmware... Done.
Fresh start, and boom, hardware setup shows my card and interfaces !
Thanks for your help and educated leads
Raf
  #18
Old 05-08-2023, 12:20 PM
nsureit nsureit is offline
Hooray!!! Glad you figured it out.
  #19
Old 03-24-2024, 01:53 PM
juansava juansava is offline
Did anyone figured out how to install the necessary driver for HDX card to be "installed" in the PCI area and be seen as connected and compatible while while connected via Sonnet Thurnderbol chasis?
I have a Sonnet Echo HDX version, an HDX card and Pro tools 2024.3. on my mac studio ( M2 and Sonoma 14.1) and Also a Mac book pro 2019 with Monterrey ... It is not recongnized or connected...
Both sites shows compatibility ( Sonnet and Avid) so Iam assuming it may be a driver thing.. I downloaded the latest available Pro tools HD Driver but that did not fix it for me... Wondering of someone here got it solved?
Sonnet Echo 3 Chasis not Recognized my Mac Studio/PT budster Pro Tools HDX & HD Native Systems (Mac) 49 06-14-2023 04:24 AM
Mac Studio - Sonnet Echo Express III Pro Tools Error kaonashi Pro Tools HDX & HD Native Systems (Mac) 5 04-24-2023 03:01 PM
Protools HD Native PCI card + Sonnet Echo + Omni Cryos Buy & Sell 0 01-16-2023 01:49 AM
anyone using the Sonnet - Echo III Desktop HDX-3 enclosure? MixerGuy Pro Tools HDX & HD Native Systems (Mac) 4 09-29-2021 08:20 PM
FS: Sonnet Echo Express III-D for HDX card pl007 Buy & Sell 2 03-09-2021 07:14 AM
