Old 01-26-2022, 03:07 PM
m.monty m.monty is offline
Default Avid TB3 Chassis AUX power cable issue
First post here, so thanks in advance to anyone willing to offer some guidance.
I got a used HDX card that came with 2 AUX power cables (1 for MAC, 1 for PC). The problem is that neither one fits into a new Avid branded TB3 chassis. The MAC cable connector is just different to the 6 pin connector on the chassis (attached photo).
The seller of the used HDX cards assured me that he included every cable that came with the card, so I am not sure what to do. The Sonnet TCB-HDX could actually work but it’s been discontinued. After doing some research here I found other threads here pointing at the same issue but I am not sure that this has been solved once and for all.
Does AVID put whatever cable comes to their mind when they ship their HDX card boxes?
The chassis is fairly new in the market so I really don’t see why there should be any incompatibility.
A user in another thread kindly pointed to an appropriate cable which should work (pn 9180-60004-00). The problem is that I just can’t find one available to ship in the EU. It just seems so strange..no one ever needs it? In the US, only on special order from BHPhoto?
Or maybe is there an adapter I could use to easily fix this?
Coming from the UA ecosystem, where everything just works and support is always a few clicks away, I have a feeling that I am entering a world of pain…
Hopefully it’s just a bad start
Sorry for the rant..
File Type: jpg C28A63EF-31D2-4267-B8F9-FFB345C93C29.jpg (72.1 KB, 0 views)
Old 01-26-2022, 03:19 PM
BScout BScout is offline
Default Re: Avid TB3 Chassis AUX power cable issue
Later HDX cards came with a third cable when the chassis (and new Mac Pros) came out. For a few years now. Avid added the cable when it was necessary -- you just bought used.
Belkin makes a cable that will work (as part of a very expensive set of cables for the Mac Pro)
Not really Avid's fault. They provided the solution when it was needed.
Old 01-26-2022, 03:40 PM
Thanks a lot! I’ll have to go with the Belkin then
Old 01-05-2023, 08:43 AM
charlie Beans charlie Beans is offline
looking for the same cable now. How did this work out for you OP ?
Old 01-11-2023, 09:06 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Is Sonnet online sold out?
I bought direct from them.
Old 02-02-2023, 10:07 AM
DHS DHS is offline
They are discontinued on sonnets website.
Old 02-16-2023, 02:44 AM
Sorry to reply so late, I missed the notification. I purchased the Belkin adapter on Amazon and it worked ok.
Old 03-18-2024, 09:39 AM
fastermaster's Avatar
fastermaster fastermaster is offline
Can you please post a link where to purchase or any information about this Belkin cable?
Matteo FasterMaster Cifelli
Producer-Engineer
Old 03-18-2024, 12:15 PM
DetroitT's Avatar
Mini PCIe power cable
https://a.co/d/gSxHpAZ
However this link gives you not just the part.
HDX TB3 Chassis- Power Cable Mixedbyjoe Pro Tools HDX & HD Native Systems (Mac) 4 10-24-2021 10:33 AM
Avid Thunderbolt 3 Expansion Chassis and inside Power connector Issue MARVINBASS Pro Tools HDX & HD Native Systems (Mac) 3 01-21-2021 11:16 PM
Avid HDX thunderbolt 3 Rack power cable Nephew312 Pro Tools HDX & HD Native Systems (Mac) 3 06-20-2020 05:29 AM
Avid SYNC HD W/ Serial & Power Cable, $800 lucienpalmer Buy & Sell 0 09-07-2019 08:05 AM
The dreaded power cable issue "Strikes Again" DJ Rae C FireWire & USB Audio Interfaces (Mac) 0 05-25-2013 12:11 AM
