Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 11-17-2022, 02:01 AM
martthie_08 martthie_08 is offline
Default Re: Any way to prevent Avid HD I/O default to 192kHz
Originally Posted by BScout View Post
You don't need a startup script. Setting the clock once in Audio MIDI Setup makes it stick. (only unless you update/change the driver could it change because then it sees it as a new device)
If it doesn't stick, you have a corrupt system file (best to delete the plist file for AMS and let it rebuild)
Thanks for your post, yes in theory this should work!
After deleting the Device and System settings in /L*/P*/Audio the USB interface that I use for system sound outside of ProTools still defaults to 192 KHz.
The HDX card did indeed remember the 44.1 KHz setting but I fear it is only a matter of time before it will jump to 192 KHz, as it keeps doing every couple of weeks.
Will report back though, thanks again!
edit: I will experiment though replacing the USB interface with a AVB based interface as it might be the 100ft USB extender causing trouble.
Default download folder in Avid Link? babaorum Pro Tools 2018 0 12-28-2018 02:20 AM
192khz recording capt kirk Pro Tools 9 1 02-12-2012 09:16 AM
Avid Drivers Prevent Sleep - Why? GordonFreeman macOS 63 05-04-2011 07:53 PM
I cant go to 192KHZ KINGDRAGON Tips & Tricks 2 01-29-2010 11:57 PM
How many of you record on 192kHz? mantaray Pro Tools TDM Systems (Mac) 3 07-02-2005 09:18 AM
