Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 04-23-2020, 03:55 AM
Kayonardo Kayonardo is offline
Default Audio dropouts all the time
Hello,
I was a Pro Tools user for a long time and now installed the test version again to bounce some old vocals from a few months ago. The problem is, I have audio dropouts all the time. Never experienced this before. The vocal tracks almost sound like a censored version. Every few seconds there is a word or sentence missing. (Other parts of the song every time I playback, not always the same parts missing) Its with playback and also when I bounce. I tried it with different buffer size and cache size, makes no difference.
Has anybody an idea?
I work on a imac pro with Mac Sierra.
Many thanks!
Old 04-23-2020, 04:12 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Audio dropouts all the time
Hi, a little more info is needed here. Please take a look at the Help Us Help You page that is linked to the forum header.
Janne
Old 04-23-2020, 01:51 PM
While we wait for more info, here are a couple of things to check:
1-What happens if you bypass all plugins on the vocal track?(if it sounds fine, then its a plugin causing the dropout. Maybe running in a demo mode)
2-is all audio dropping out, or just a single track? If its all audio, bypass all plugins on any master and/or mix bus routing(again, suspect a plugin)
3-what is your playback buffer set to? If its low, bump it up to 1024 and see if that alters things.
4-is the dropout consistent or random?(consistent meaning its always the same spot, the same word, etc).
Old 04-24-2020, 11:25 AM
Rajsmoove Rajsmoove is offline
Had the same issue. Go to apple system pref/ date&time. Uncheck the automatically detect time using current location and the same with time zone on the 2nd tab. As unrelated as this seems, since I did that I haven't had any more audio drop outs.
Old 04-24-2020, 04:09 PM
Intransit Intransit is offline
Is that a real solution? lol. Because I'm getting audio dropouts too, totally clean install of 2020.3 and Mojave 10.14.6
iMac Retina 5K, 2020, 3.6 GHz 10-Core Intel Core i9, RAM 72GB
HD Native PCIe card /// OWC Mercury Helios 3S
PT 24.3.0
Old 04-25-2020, 09:32 PM
Amazingly yes lol. I googled it and the results came up about the date and time. I did it and haven't had one dropout since. Was something about the t2 chip checking the network connection blah blah blah. All I cared was that it worked. It was happening across all audio coming from my computer. Go figure. I was mad at PT until it came up being an apple bug
Old 02-02-2022, 03:17 AM
chrismeraz chrismeraz is offline
I have the exact same problem, but the automatic time settings didn't work for me, unfortunately.
I disabled all plugins in the session, row by row. Once the problem went away, I knew it was a plugin, and I knew what insert row it was in. So I went down that row disabling plugins one by one until I found what plugin it was. Turns out I forgot to activate Ozone 9, that's all.
Hope this helps someone else!
ATC SCM50ASL
Apollo x8
MacBook Pro M1 MAX
Pro Tools Studio
www.studioaix.fr
Old 07-05-2022, 07:45 PM
thephog89 thephog89 is offline
YOU SIR, ARE A GENIUS. Lord that was absolutely killing me. Was about to mess with Apple date & time, then reading that above I realized it was Ozone 9 - new computer, it hadn't Authorized yet. WOW. Thanks!
Old 06-14-2023, 10:51 AM
waylandprod waylandprod is offline
Just wanted to add in a thanks as well as a comment, I experienced the same thing, and it was due to an iLok being plugged in, but was not connected. I had an insert plugin for iZotope declick, and the same happened. Fixed connection and re-opened and we are good to go! Thanks :)
Old 10-12-2023, 01:55 AM
dk01 dk01 is offline
LOL so random, and to always trip on same things that get us all.
I almost went into the registry to simply delete the entire clock on PC
Thanks you all - for all else, especially when going into a session from like 10 years ago in this case of mine... PLUGINS, IN DEMO MODE... Not sure why.
I hadn't disabled everything.
Dayz
Audio Dropouts Cliffy_Boy Pro Tools 11 27 02-23-2015 08:32 AM
Audio dropouts at 48k youngas75 Pro Tools 11 2 11-06-2013 08:25 AM
Audio Dropouts in PT 8 sricabla 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-10-2010 06:12 AM
audio dropouts 2000mpc General Discussion 1 07-09-2010 01:18 PM
Audio dropouts help YUL Digidesign Hardware & Software 0 11-13-2001 08:06 AM
