Old 03-03-2019, 01:18 AM
Jc Dusse Jc Dusse is offline
Default Re: only when punching in, the track's playback is ahead?
Do you have a bug number we could track ?
Also, it seems it is a pretty new bug, rolling back to an older version (2018.4) could fix this specific issue.
Old 03-31-2019, 12:24 PM
edwinstar's Avatar
edwinstar edwinstar is offline
PT-249648
Record enabled audio tracks play early when LLM is enabled (new to PT 2018.7)
PT-249649
Record enabled tracks play early when LLM and HEAT are enabled (new to PT 2018.7)
Yes, 2018.4 doesn‘t have this bug!
Gesendet von iPhone mit Tapatalk Pro
Old 03-31-2019, 03:45 PM
jjnssn jjnssn is offline
Default only when punching in, the track's playback is ahead?
Originally Posted by edwinstar View Post
PT-249648
PT-249649
Were these fixed or are they still outstanding in 2018.12?
Old 04-09-2019, 12:47 AM
edwinstar's Avatar
they are still outstanding!
Old 05-09-2019, 11:52 AM
This issue doesn't appear in the bug fixes list.
Has anyone installed 2019.5 ? Please tell me that I'm wrong ?
  #16
Old 06-04-2019, 04:53 PM
edwinstar's Avatar
it‘s not yet fixed, sorry!
  #17
Old 06-27-2019, 01:06 AM
blastula blastula is offline
I had a problem like this... then realized I’d forgotten that I had to command-click on the record button to go into “punch mode”
  #18
Old 10-22-2019, 04:54 AM
edwinstar's Avatar
Thanks for your input, but the problem persists with or without Quickpunch enabled.
  #19
Old 07-07-2020, 09:00 AM
Jeremy David Jeremy David is offline
I'm experiencing this same issue, on v 2020.5.0... anyone else?
  #20
Old 07-10-2020, 06:18 AM
Assuming you are not running HDX, this might be due to plugin ADC. Start by setting MIX window to show Delay Compensation and check the numbers(especially the bottom of the 3 as that is the total Delay Compensation). If the numbers are more than 32(give or take), that will create a problem when you enter record, because the delay compensation is disabled on any track in record(which would put your new audio ahead of other audio that is delayed due to delay compensation).
Best practice for tracking(non-HDX) is to set the buffer to 64(assuming 44.1 or 48K) and disable any plugins that show more than 10 samples of latency. In the case of a large session with plugins that you really NEED to hear during an overdub, I would bounce a mix>Import into the session>nudge into perfect alignment>Make all tracks inactive(except the new bounced mix) and record overdubs to that. Once finished, mute the 2-mix and re-activate all tracks. LLM can SOMETIMES help, but it often either just doesn't work, or won't quite do what you want
Delay compensation issue? Note playback ahead of time moshuajusic Pro Tools 12 7 02-23-2017 07:44 PM
I stop Playback and then jumps one frame ahead Azul3 Pro Tools 11 4 02-22-2016 09:02 PM
Punching and Post-Playback hutchinson9736 Pro Tools 9 5 06-26-2011 04:35 PM
Recorded MIDI is ahead in playback BiggiT MIDI 7 06-06-2007 11:17 AM
tracks playback 1.4 seconds ahead KenSluiter Pro Tools TDM Systems (Mac) 5 01-12-2005 10:52 PM
