Old 05-26-2018, 03:39 PM
my-name-is-thanos my-name-is-thanos is offline
Default Signal Generator
Is it possible to create frequencies in fractions rather than whole numbers? (ex. 61.74)
Old 05-26-2018, 04:41 PM
Default Re: Signal Generator
Why not just try it?
Signal generator works to more decimal places than it displays, as you can see by mixing two instances of signal generator against each other. Easily works to 10 millihertz resolution at say 200 Hz. If you have more patience to sit longer listening to the frequencies beat together you should be able to find the resolution floor.
Since that is the frequency of B1, I'm guessing there are no technical issues with your intended use, like frequency stability/phase noise specs.
Old 05-26-2018, 09:07 PM
I've tried typing fraction numbers like 61.74 into the box but it always rounds off to 62.
Old 05-26-2018, 09:13 PM
Yes it does, but then it uses some number of the hidden digits. Not the cleverest bit of UI behavior.
Old 05-26-2018, 10:56 PM
Ok, so if you type 61.74 then it really is using 61.74 even though it's showing 62?
Old 05-26-2018, 11:23 PM
That is not exactly what I said. Read my very first reply. It uses some of those extra hidden digits, maybe all, how many... you can test and check...
Old 03-09-2024, 11:45 AM
inspire inspire is offline
I created a ticket to iZotope support for the same question - Signal Generator - Is it possible to add three decimal places after the comma. This is necessary for generating the frequency of notes!
Windows 11 Home Version 23H2
Pro Tools Artist Version 2024.3.1
Old 03-09-2024, 12:39 PM
BScout BScout is offline
Why?
Signal Generator is Avid's plugin.
iZotope have nothing to do with it.
Old 03-09-2024, 01:05 PM
I was not aware. Will Signal Generator Avid's plugin allow these three places after comma?
Old 03-09-2024, 03:04 PM
Sigh. *Again* just try stuff.
Stick the signal generator plugin on two aux at the default 1000 Hz. Manipulate one by trying to reenter it's frequency as 1000.1 or 1000.01 or 1000.001 Hz etc. Observe the beat frequency. Question answered in minutes instead of this silly thread.
No Signal Generator lederhosen Pro Tools 10 7 03-07-2016 01:44 PM
Is Signal Generator gone?! nz Pro Tools 9 1 12-27-2010 07:39 AM
Bug in 7.2 Signal Generator Craig F Pro Tools TDM Systems (Mac) 1 10-12-2006 03:17 PM
Signal Generator gone!!!! clausiii 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-05-2003 03:22 AM
signal generator for what use? jinsel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-11-2002 03:01 PM
