Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Duet & Pro Tools | Quartet
Old 10-30-2014, 09:23 AM
dizzy123 dizzy123 is offline
Default pro tools duet questions
Hi
Just installed pro tools duet and pro tools 11 on my computer. Windows 7 64 bit.
1. Should the pro tools duet control only open as a stand alone program? On my system I can open the duet control and run it along with pro tools 11 but it does not open as part of pro tools. This works fine but I am making sure it is normal.
2. My midi port on the duet is not working. I did some trouble shooting. The midi controller works when plugged into the computer usb port. It triggers instruments in protools etc. But when I plug it into the port on the duet it does not register.
I forget the name of the midi controller but it does work with pro tools normally.
Thanks
Pro tools 10 with Apogee Duet ? Vides7 Pro Tools 10 1 01-02-2012 12:20 PM
Pro Tools and Apogee Duet Rhythm_Writer Pro Tools 9 13 04-15-2011 04:41 PM
Pro Tools 9 and Apogee Duet Rhythm_Writer macOS 1 04-12-2011 12:08 PM
Pro Tools 9 with an Apogee Duet Crow74 Pro Tools 9 24 12-27-2010 04:34 PM
Apogee Duet & Pro Tools 9? bradweeks80 Pro Tools 9 4 12-24-2010 10:47 PM
