Old 12-14-2007, 05:55 PM
Nicholasguitar Nicholasguitar is offline
Default How close is too close for monitors...
I remember someone telling me once that if you leave a hard drive too close to a speaker, you can lose data through demagnetizing it. I have a MBP running LE and I have some Rokit 5s on the same surface about 1ft away from each end of the MBP. If when turned up, can I possibly loose data or eventually ruin something... same questions goes for the visual monitor as well (as far as placing audio monitors next to a visual monitor)
Nick
Old 12-14-2007, 06:05 PM
paul_g's Avatar
paul_g paul_g is offline
Default Re: How close is too close for monitors...
Good question. I have my external HD's sitting right beside my Left Monitor.
5K Retina 27" (2020) iMac OS 13.6.5 Ventura
3.3 GHz 6-Core intel Core i5
AMD Radeon Pro 5300 4 GB
64 GB 2667 MHz DDR 4
Internal 2TiB SSD
Pro Tools 2024.3
EuCon 4.8.6.41 / 2023.11
UA Luna
UAD 11
UA Apollo Twin X
Avid S1 / Fire10 - 21.8.1.0
PreSonus DigiMax FS 8-input ADAT
Dynaudio Monitors
PreSonus Temblor 10 Sub
Check my Music out here:
Paul G YouTube
Paul G Bandcamp
Old 12-14-2007, 06:13 PM
Craig F Craig F is offline
well about 9 years ago, as a test we left a 3.5" floppy from a digital camera on top of an NS-10 all day and everything was readable when we checked it
Thank you,
Craig
Old 12-14-2007, 07:55 PM
Len8 Len8 is offline
Most standard "quality" near field monitors have magnetic shielding so they don't interfere with CRT monitors. That shielding would reduce the impact of monitor magnetic fields from harming drives.
Old 12-14-2007, 08:10 PM
yes, there are speakers that have shielding but the venerable NS-10s don't have shielding or bucking magnets
Thank you,
Craig
Old 12-15-2007, 02:28 PM
Might be one of those things that's talked about but never happens... hopefully.
Old 12-15-2007, 08:31 PM
paul_g's Avatar
well, I'm in IT and had to destroy data on disks before disposing of them. Me and some colleagues bought these huge honkin' magnets (from a tape destruction device)... Each magnet weighed about 10 lbs each! Put the right on top of the drives.
When we put the drives back in the PC's, they booted up without issues. We looked at each other and laughed. We figured it wouldn't work, but gave it a shot...
So, needless to say, the magnets on the back of your monitors probably won't do anything to your HD, but the possibility always exists...
Internal 2TiB SSD
Pro Tools 2024.3
UA Luna
UAD 11
UA Apollo Twin X
Dynaudio Monitors
Paul G YouTube
Paul G Bandcamp
Old 12-15-2007, 10:18 PM
OddsAre OddsAre is offline
First of all 1 ft away is more than adequate, considering as someone previously said, modern nearfield monitors are usually shielded. Normally to erase a tape or hard disc you would use a circular motion as oppose to just placing it at a constant distance and waiting. I am quite cautious none the less and always keep my externals away from magnets, its a good practice. Lastly turning the monitors up won't increase the amount of power of the magnets. Even at full blast it won't be any better or worse, it will be the same as if no audio was running through it.
Conclusion is: use common sense and keep your hard drives away from magnets, keep your monitors as far away from your laptop as will allow an optimal equilateral triangle between them and your sweet spot, and always back your system hard drive up on a regular basis in case the inevitable happens. You are probably more likely to have a hard drive failure than to have your monitors erase your hard drive.
Mac Book Pro Retina 2.6 GHz i7 Quad | 16GB | OSX 10.8.5 | Digi 002 | Apogee Rosetta 800/96 | PT 10 | Waves Gold/RevMaxx V9
Is PDC Close? rockville Pro Tools M-Powered (Win) 8 09-17-2009 12:48 PM
I cant close my pt8!! Sergioam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-18-2009 11:17 AM
i'm this close | | reyalp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 03-17-2008 09:32 AM
Doh so close but so far. hi_robb Digidesign Hardware & Software 1 04-02-2001 12:52 AM
How close could the I/O box be to the monitors toecat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-13-2000 06:00 PM
