Old 10-27-2007, 03:52 PM
zakco zakco is offline
Default Big Ben / PT sample rate mismatch
Hi there,
In a moment of extreme distraction I started a new project with PT clocked to a big ben with the project SR set to 44.1 but the big ben at 48k. The result is 44.1 audio files that need to be clocked to 48k to sound right. I tracked 2 songs like this before I realized it. As long as I keep this mismatch the session plays back at the correct speed/pitch. Problem is when I bounce to disk at 44.1 the file is slow/flat.
What is the best way to convert this PT session to true 44.1 and keep the correct speed/pitch?
Thanks,
-Zak
Old 10-27-2007, 05:38 PM
digimatek digimatek is offline
Default Re: Big Ben / PT sample rate mismatch
Hi there,
Thanks,
-Zak
Zak, this is a pretty easy fix. So they are 48k audio files living in a 44.1k session. So you need to get those audio files into a 48k session.
Do this:
Create a new PT session with the SR set to 48k.
Then do a "import session data" from the other session. There should be a check box to do SR conversion. Uncheck the box. Import all your tracks and your back in business.
-JD
Old 10-27-2007, 06:36 PM
JD,
Thanks! Worked just fine. I'd been trying to go the other direction to 44.1 first. Duh!
I should rack the BB where I can actually see it
-Zak
Sample Rate Mismatch! (clock 44.1, PT 48) RhodesB3 Pro Tools TDM Systems (Mac) 22 11-24-2015 12:17 PM
sample rate mismatch problem? Kevin_28 Pro Tools 9 4 12-22-2010 11:18 PM
Sample Rate Mismatch... How to export files as regions after problem. Dizzi45Z Pro Tools TDM Systems (Mac) 2 04-24-2010 10:17 PM
Pro Tools LE Sample Rate Mismatch Nag tcassel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-20-2007 12:51 PM
sample rate mismatch with HD24 on whole session BuddySchaub 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-10-2004 12:53 PM
