Old 05-11-2005, 08:02 AM
Diesel1 Diesel1 is offline
Default ASIO4ALL and Pro Tools?
Has anyone installed this ASIO4ALL driver and using Por Tools v.6.9 and having issues or not having issues but reduced latency after installing this driver? Anyone's input whether bad or good would be greatly appreciated. Has Digidesign certified or tested this driver with any Pro Tools version? Any input from Digidesign would be greatly appreciated as well.
Old 05-11-2005, 12:45 PM
JMS40 JMS40 is offline
Default Re: ASIO4ALL and Pro Tools?
Why not use the Digidesign ASIO driver?
Old 05-11-2005, 01:57 PM
Well apparently this driver is supposed to reduce latency and from what I've read and heard, it does have some issues depending on it's use but I haven't read or heard of anything negative or positive on Pro Tools. Basically there hasn't been any discussion about this driver with Pro Tools.
Old 05-11-2005, 01:59 PM
Gunnar Hellquist Gunnar Hellquist is offline
Protools itself does not use ASIO, it goes directly to the hardware. So the only reason to install ASIO4ALL is if you want to run another program using the MBox or 001 /002 or whatever. But then again, Digidesign does supply a free driver that in many cases is good enough.
Gunnar
Gunnar Hellquist
true amateur
Old 05-11-2005, 02:08 PM
That's probably because most of us are using the Digi driver provided with Pro Tools.
Search the DUC, this forum, for "asio".
I stopped counting at 10 pages of discussions that reference the ASIO driver... and that only took me back to February of this year.
Granted, not all are in depth specific ASIO topics, but there is useful information there for you.
Personally, I find the Digi driver to be pretty trouble free.
Old 05-11-2005, 06:39 PM
Phiktion Phiktion is offline
Hey man, where can you find that driver? I'm sick of the digi asio driver! I use a ton of things that need it, and im appauled by its jankyness! When I had an M-audio set-up, that asio driver worked perfect. If I can find the asio4all, im going to have to try it! thanks
Old 05-11-2005, 06:48 PM
spkguitar's Avatar
asio4all.com
I prefer the digi one.
Old 05-11-2005, 06:55 PM
Chris Cavell Chris Cavell is offline
I've never encountered a single issue with the digi Asio driver to date with any of my numerous asio based applications.
Cavell Studios
Old 05-12-2005, 06:17 AM
Hey Phiktion, when you install it, why don't you let us know if it works great with your PT and any other asio based software you have.
Old 05-12-2005, 07:07 AM
What does jankyness mean? From the context, It sounds like it doesn't work well but I'm not sure. It works for me.
Obsidian Dragon
Mac Studio M1Max - 64GB
No Sound Pro Tools HP Laptop asio4all malmalibu Windows 14 11-25-2013 04:47 PM
Pro Tools 10 asio4all HP Pavilion no sound malmalibu Pro Tools 10 1 08-29-2013 06:22 PM
Pro Tools 10 asio4all no audio malmalibu Windows 3 08-29-2013 06:19 PM
Help needed using USB mic with Pro Tools and ASIO4all rockguitarist1255 Pro Tools 10 6 06-30-2013 02:09 PM
Pro Tools 10 & ASIO4ALL on a Mac running Windows aj88keys Pro Tools 10 1 01-09-2012 01:39 AM
