Opening Help! ProTools 8.03-Get's stuck loading AutoTune 5
Ok, so I wiped off the drives and re-loaded Windows XP Pro SP 3, as well as Windows & Ultimate instead of trying to run PT through Win7, I just use XP, and then use Win7 for everything else...and now it works like a dream!
One big problem though... I installed Auto-Tune 5 RTAS, and now when opening PT, it gets stuck on "Loading Plug-Ins: AutoTune.dms", and stops responding, and I have to manually shut down PT. Any ideas??? Pro Tools 8.03 Auto-Tune 5 Here's the SANDRA report: SiSoftware Sandra Computer Model : Gigabyte GA-MA790GPT-UD3H Processor Model : AMD Phenom(tm) II X4 945 Processor Speed : 3GHz Cores per Processor : 4 Unit(s) Threads per Core : 1 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 64kB, Synchronous, Write-Back, 2-way, Exclusive, 64 byte line size L2 On-board Cache : 4x 512kB, ECC, Synchronous, Write-Back, 16-way, Exclusive, 64 byte line size L3 On-board Cache : 6MB, ECC, Synchronous, Write-Back, 48-way, 64 byte line size, 4 threads sharing Computer Mainboard : Gigabyte GA-MA790GPT-UD3H BIOS : Award (Phoenix) F3 09/16/2009 Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 3.25GB DIMM DDR3 ChipKill Chipset Model : AMD RS780 Host Bridge Front Side Bus Speed : 2x 2GHz (4GHz) Memory Bus Speed : 2x 101MHz (202MHz) Chipset Model : AMD F10h Athlon 64/Opteron/Sempron HT Hub Front Side Bus Speed : 2x 2GHz (4GHz) Total Memory : 4GB DIMM DDR3 ChipKill Memory Bus Speed : 2x 804MHz (1.6GHz) Memory Module(s) Memory Module : G.Skill F3-12800CL9-2GBNQ 2GB DIMM DDR3 PC3-12800U DDR3-1600 (10-10-10-27 4-37-11-6) Memory Module : G.Skill F3-12800CL9-2GBNQ 2GB DIMM DDR3 PC3-12800U DDR3-1600 (10-10-10-27 4-37-11-6) Storage Devices ST3500320AS (500.1GB, SATA300, 3.5", 7200rpm, NCQ) : 466GB (C:) (D:) PIONEER DVD-RW DVR-111D (ATA33, DVD+-RW, CD-RW, 64kB Cache) : 526MB (E:) Logical Storage Devices Hard Disk (C:) : 270GB (NTFS) @ ST3500320AS (500.1GB, SATA300, 3.5", 7200rpm, NCQ) Hard Disk (D:) : 195GB (NTFS) @ ST3500320AS (500.1GB, SATA300, 3.5", 7200rpm, NCQ) Auto-Tune 5 Nati (E:) : 526MB (CDFS) @ PIONEER DVD-RW DVR-111D (ATA33, DVD+-RW, CD-RW, 64kB Cache) 3.5" 1.44MB (A:) : N/A Peripherals LPC Hub Controller 1 : Giga-Byte IXP SB600 SMBUS Controller LPC Hub Controller 2 : ATI (AMD) SB700 LPC host controller LPC Legacy Controller 1 : ITE IT8718F Audio Device : Giga-Byte IXP SB600 High Definition Audio Controller Audio Codec : Realtek Semiconductor Realtek 885 High Definition Audio Serial Port(s) : 1 Disk Controller : Giga-Byte SB700 SATA Controller [IDE mode] Disk Controller : Giga-Byte SB700 IDE USB Controller 1 : Giga-Byte SB700 USB OHCI0 Controller USB Controller 2 : Giga-Byte SB700 USB OHCI1 Controller USB Controller 3 : Giga-Byte SB700 USB EHCI Controller USB Controller 4 : Giga-Byte SB700 USB OHCI0 Controller USB Controller 5 : Giga-Byte SB700 USB OHCI1 Controller USB Controller 6 : Giga-Byte SB700 USB EHCI Controller USB Controller 7 : Giga-Byte SB700 USB OHCI2 Controller FireWire/1394 Controller 1 : Giga-Byte TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller SMBus/i2c Controller 1 : ATI SB600 SMBus SMBus/i2c Controller 2 : ATI AFS SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Network Services Network Adapter : Realtek PCIe GBE Family Controller - Packet Scheduler Miniport (Ethernet, 100Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows XP Professional 5.01.2600 (Service Pack 3) Platform Compliance : x86 Performance Tips Warning 100 : Large memory sizes should be made of Registered/Buffered memory. Tip 2546 : Large memory modules should be ECC/Parity. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. |
Re: Opening Help! ProTools 8.03-Get's stuck loading AutoTune 5
i have the same exact problem. except this is the first time i am installing pro tools on my pc. i get the error at the same auto-tune plugin. if u find a fix please share.. i re-installed, repaired, and modified but none of those worked for me.
Don't forget that after installing Auto-tune, you have to run the authorization wizard before starting Pro Tools. Look in the Antares folder in your start menu.
Do you have autotune authorized in your ilok?
Is there not a way to get past this, by holding down some keys when starting up Pro Tools?
PC 7980XE @ 4.2 PT 12.7 Ableton 10.0.1 Great River ME-1NV, Ehrlund EHR-M, Axiom Pro 49, Brauner Valvet, Oktavamod MXL-910, RODE NT5 with Oktavamod MJE-384K, Crane Song Trakker, SSL 611EQ, SSL X-Desk, Sennheiser HD600/650 IS Pro Double 6" Speakers, www.intelligentsound.se/ |
Yes, I have it authorized from my iLok, and the software gave me the confirmation message, saying,"This software has already been authorized by a connected iLok device, your ready to go!"
I even followed the "general troubleshooting repair guide" from the AntaresTech.com/Answerbase, and updated all the iLok drivers and eveything, and still doesn't work. Right now, in order to open PT8, I have to uninstall AutoTune. |
OK, this is what happened to me with 8.0.3/4b. Auto-Tune would not run in RTAS so I grabbed the VST DLL and put it in the VST to RTAS adapter, and all was well. For RTAS anyway... No Audiosuite.
When's it's loading, it's almost like PT either can't load it, or the actual program is not in the folder that it's trying to load.... any idea's anybody?? |
Ok, so I downloaded the PT version 8.03cts1...i'm running in XP so do I need to download the Win7 Beta drivers (vrs. 8.0.3/4b)?? And i have the native version of AutoTune... is that what your talking about? How would I do what you did?? :)
OK!!! I fixed it!! Apparently this is the same problem with Internet Explorer! Here's the instructions, as well as the link to the page they're on for more info if you're running IE8.
Hope this works for everyone the way it did for me! Loaded AutoTune, and it works just fine, in the Audiosuite and everything! http://avid.custkb.com/avid/app/self...p?DocId=289041 Pro Tools stops working or does not launch on Windows XP or Windows Vista[289041] Behavior observed in Vista:
Instructions to modify internet settings
Session getting stuck while opening | Micah777 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-24-2010 04:39 PM |
Stuck loading LE8? | Stixxs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-25-2010 08:46 PM |
When loading PT 7.4.2 gets stuck on 'DigiRewire'...please help!! | larsizzle | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 09-29-2008 04:09 PM |
002 STUCK IN VALIDATING AND LOADING SCREEN | (BANGAH) | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 07-23-2003 10:50 AM |
Protools 5.1 LE freezes when loading (DAE is stuck?) | blazer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-28-2002 12:03 AM |
