Issue with BOOM
I just updated to PT8, after installing the whole lot successfully I had a joyful day playing with new toys that came with this major update, one of them naturally being BOOM. Today when I opened the same session BOOM didn't played back the midi notes as a matter a fact it didn't even recognized the incoming midi notes when I pressed record, only when I made a new track and put a new instance did it started responding? Does anyone have similar experience and is there a workaround? Much Obliged,
MacBookPro 2.2 Ghz MacOSX Leopard 10.5.8 Digi003 PT LE 8.0.3 |
Re: Issue with BOOM
Hello Daddo.
Have you installed any third party plugins in adition to PT LE8 ? Have you upgraded to PT8.0.1cs2 ? http://avid.custkb.com/avid/app/self...p?DocId=364871 |
Re: Issue with BOOM
Hi Chris, and thank you for your quick response,
Yes indeed I have 3'd party plug ins, but to my knowledge they are all certified as compatible with PT le 8 and no I haven't installed any of the .cs versions yet instead I went straight for the 8.0.3 thinking this had all issues resolved ...?
Re: Issue with BOOM
I would first try removing all thirdparty plugins from the plugins folder to the unused plugins folder. If that doesn't help, I would try removing preferences. If that doesn't help I would try upgrading to 8.0.1cs2.
Do you have a clean image backup of your system ? |
Re: Issue with BOOM
Thanks Chris,
Tried all of the above... even did a clean uninstall and installed PT again... no luck... when I removed all of the 3d party plugins and restarted the session I still had a same problem, funny thing is it's only with BOOM instrument track, if I root it from a midi track it works and xpand works just normally? I'm open to suggestions cause I like things to work as they should, for the moment I have this fix with an extra midi track...
Re: Issue with BOOM
Okay...
Have no idea what was the problem.. but whatever it was it's solved now... I guess somewhere something was leftover and got stuck in the session ... I removed the BOOM instrument track, made new one, beforehand I saved my work into a preset list, inserted a new inst.track placed a new BOOM instance and loaded my preset. saved, restarted PT, and... magically everything works as you would expect it to !!! Me Happy !!! Chris thank you for helping out !
Boom needs file Boom.big to run? | jonsimoneau | Virtual Instruments | 4 | 01-01-2012 03:40 PM |
Boom programming issue | MotifMan | Virtual Instruments | 7 | 03-13-2010 01:17 PM |
Virtual Intrument "Boom" Issue | firsty33 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-25-2010 12:20 PM |
Boom issue | pigpen | Pro Tools TDM Systems (Mac) | 1 | 05-18-2009 03:50 PM |
Boom | wade12 | Virtual Instruments | 46 | 05-15-2009 02:06 PM |
