Old 05-07-2007, 06:22 PM
GlennR01 GlennR01 is offline
Default No Fader Flip In Custom Fader Mode?
Curious if this is by design, but cannot get my faders to flip in custom fader mode on my D-Control. Thoughts?
Mac Pro 2013 2.7GHz 12 Core 128GB • Mac OS 10.5.5 • PT Ultimate 2020.5.0 • PT HDX3 • 192 IO x 8 • D-Control 32 Fader • UAD2 Octo Ultimate
Old 05-07-2007, 08:29 PM
PTGuy PTGuy is offline
Default Re: No Fader Flip In Custom Fader Mode?
speaking of that I can't my faders to flip in any mode. Not even to flip the pan controls down to the faders.... any thoughts?
Old 05-07-2007, 08:48 PM
Craig F Craig F is offline
use the Command or Control modifier button when pressing the Flip button
Thank you,
Craig
Old 05-08-2007, 08:21 AM
digimidi's Avatar
digimidi digimidi is offline
On D-Control, there is a dedicated flip button in the custom faders section.
Gil
Gil Gowing
Principal
Digimidi Technical Services
Old 05-08-2007, 07:57 PM
Gil, Gil, Gil... I just didn't want to bug you.
Thanks, I'll check this out.
Glenn
Old 05-20-2007, 07:47 AM
OK, flip button works fine in Custom Faders mode. Curious if the flip order is "one way" - or can you use a modifier key combination (option, shift, etc.) to "reverse" the flip order. I tried a few key commands, but wasn't able to affect the direction of the flip.
Old 05-20-2007, 06:23 PM
digimidi's Avatar
It is only one way. Sorry...
Gil
Gil Gowing
Principal
digimidi's Avatar
Gil
Gil Gowing
Principal
Old 05-23-2007, 10:03 PM
Chris Lambrechts's Avatar
Chris Lambrechts Chris Lambrechts is offline
Here's a couple of alternatives to the flip buttons behaviour in regular fader mode :
In CF mode : to flip sends to the faders you can :
option + push 'sends' to put the entire CF section in sends view
then option + the 'select' button on any of the sends will flip that entire row to the faders
option + press 'sends' will bring back the volumes on the faders.
So essentially you can put everything on the rotaries in sends view and use the select button on the rotaries as your global flip button combined with holding the option key, option + press a select switch on row 2 for example to flip that row to the faders ... option + press the sends button to bring back the volumes on the faders .... then option + press a select switch on row 4 to bring that row to the faders and so on.
I find this way ofetn way more convenient and faster then scrolling through the rows with the CF flip button. As you pointed out ... it is only one direction ...
One tip when using the CF flip ... apple + flip will shortcut you back to having the volumes on the faders.
Now ... all that said .... here's another ... even more convenient way to working with sends but a slightly dangerous one as you have to BE AWARE that it is active :
double click the do to all button so it blinks .... now it is locked :
from here on , when in sends view you do no longer need to hold the option key ... any select switch on a certain row will bring everything in that row down to the faders ... pressing sends brings back the volumes and so on.
This is a good way to work when you're setting sends levels for reverbs / delays / fx and so on but the danger is that you FORGET to disactivate the blinking do to all button ... ... with nasty consequences as a result ... so be AWARE when you do this.
Be carefull what you push for example when automating stuff ... the bmp button is in those case VERY close to the select switch and before you know it you have written a mute automation to every send in the CF group ...
hope this helps
Chris
Chris Lambrechts
Applications Specialist- Live Sound
Old 05-24-2007, 08:36 PM
Chris, I think a visit to the U.S.A. (specifically, my studio) is in order. Great suggestions, all.
What's the music scene there like? Are you aware of Arno Hintjens?
MC Mix FADER FLIP Monkey Island Artist Series 4 05-24-2010 05:23 PM
Stuck in custom fader mode on D-Con? Inaam ICON & C|24 6 04-01-2010 12:30 PM
volume fader in custom fader mode KimSira ICON & C|24 4 10-15-2008 09:54 PM
Custom Fader Mode on D-Command (TURN OFF) EvanScottSmith ICON & C|24 1 01-31-2007 04:07 PM
Digi 002 - flying fader issue in flip mode bluemanna 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-14-2003 01:54 AM
