Can I assign a plugin to a soft keys?!?!?
Hi guys, I'm trying to assing one soft keys to a specific plugins, I use mostly one plug for EQ and one for DYN so I'd like to assign one to one softkeys and one to another......All I wanna do is :
focus one specific track press the insert rotate knob press the corresponding 8 rotate knob to determinate position insert slot and now, to avoid search every time the plugs in the list, press the soft key previously assigned to a SSLEQMono for example. is it possible?!?!?!? where can i find the key command sequence ? Thanx |
Re: Can I assign a plugin to a soft keys?!?!?
I don't think so, but it appears you have the Mix. I have the control.
But it's a great idea....fav plugs on the soft keys
I've MC Mix and MC Control V2.
Colours on soft keys | HansH | Artist Series | 6 | 09-26-2013 06:04 AM |
Assign Pause & key command to soft keys? | mikekiraly1 | Artist Series | 2 | 02-03-2012 10:29 AM |
Soft Keys | marrap | Artist Series | 4 | 11-28-2011 08:17 AM |
Can you break up samples and assign to Keys? | achapman | Pro Tools M-Powered (Mac) | 1 | 01-14-2011 01:43 PM |
What would be the perfect (Plugin, Soft Synth, Soft Sampler Library)? | rtcstudio | Pro Tools TDM Systems (Mac) | 3 | 11-16-2002 07:57 PM |
