Old 02-02-2015, 05:37 PM
360grx 360grx is offline
Default first time using PT11, fast track duo
i am trying to record some sounds and i got audio 1 track recorded. but when i try to record on audio 2 track i am getting this problem i can not see a meter response on audio 2 on play back from audio 1 , then when i tried to actually record there was no audio in audio 2 track. i hope i am making sense.. please help.
Old 02-03-2015, 07:15 AM
junkgear's Avatar
junkgear junkgear is offline
Default Re: first time using PT11, fast track duo
Have you tried defaulting your I/O settings?
To do this, go to your I/O settings, select the Input tab and press the Default button. Do the same thing for both the Output and Bus tabs, then close the I/O settings window.
Now choose your track inputs accordingly and see if that helps.
Will K
System Details
PT11 Fast Track Duo Headphones distortion!!!! troncomac FireWire and USB Audio Interfaces (Mac) 1 12-25-2014 02:22 PM
Fast TracK Pro no sound in PT11 Councillor FireWire and USB Audio Interfaces (Win) 0 09-15-2013 11:32 AM
Fast Track C400 w/ PT11 ?? sandersonc84 Pro Tools 11 1 07-05-2013 03:44 PM
PT11, Fast Track C600, 256 Buffer Only justus1900 Pro Tools 11 12 07-02-2013 07:26 AM
can i use 2 Fast Track Ultra 8R at the same time? feyddude Pro Tools M-Powered (Mac) 1 03-06-2009 11:02 AM
