Old 07-15-2004, 06:54 AM
flautista's Avatar
flautista flautista is offline
Default 6.4 install question is possible standalone
I download 6.4 LE Update and installed after 6.1 and 6.1.1, okay it works with no problems.
My question is,if in case I have a disaster and should install again, can I install 6.4 alone
whithout the before updates(6.1)I downloaded from Digipage updates.From now Thanks
Jascha Koneffke flutist
www.prodmusica.cl
GA-X58A-UD3R[/
I7 950
RAM 24Gb corsair 1600 (3 sticks)
9-9-9-24
MAC
MacBookPro i7 2,3 15"
RAM 16gb
PT 11.3
003 Rack
MBox 3 Pro
Old 07-15-2004, 07:09 AM
Bazzle Bazzle is offline
Default Re: 6.4 install question is possible standalone
I believe that you can install 6.4 directly without installing 6.1 first.Others have done it,I believe Kingfish had a thread about doing it awhile back.
Bazzle
Old 07-15-2004, 07:35 AM
flautista's Avatar
Thanks I'll try there
www.prodmusica.cl
GA-X58A-UD3R[/
I7 950
9-9-9-24
MAC
RAM 16gb
PT 11.3
003 Rack
MBox 3 Pro
Old 07-15-2004, 07:37 AM
Camilo Toledo Camilo Toledo is offline
I had many problems not only when I upgraded to 6.1. When I upgraded to 6.1.1 something were fixed. When I upgraded to 6.4 it was a huge problem.
In my own experience, the best way to go is to install 6.4 by itself. Make sure you check the options you want installed. In my case I didn't install several things, some pdf guides I just didn't want in my system, mp3, and other things.
Flautista, que fue lo que paso? cual es el problema que tienes?
Borra todo lo anterior y has una nueva instalacion de 6.4.
Camilo Toledo
Old 07-15-2004, 07:54 AM
flautista's Avatar
Hola Chuck, gracias por responder pero no tengo problemas, lo que pasa que pasé un susto con un Virus pero no fue nada, entonces pensé que si al reinstalar todo fuera posible que funcionara instalando solamente el 6.4 sin las actualizaciones anteriores.veo que a ti te resultó bien instalandolo solo. .La pregunta es por que lo que bajé de la pagina de Digi se supone que es una actualizacion, y por los comentarios que he leído y lo que me dices funciona cono programa completo.Bueno Gracias. Jascha
Hi Thanks for your answer byut I'm okay,I just was afraid about a virus but is okay now.That's whay I thought in case to reinstall if it works istalling 6.4 by itself, thinking what I download was un update from DIGI's page,so you could do it, nice,Thanks. Jascha
www.prodmusica.cl
GA-X58A-UD3R[/
I7 950
9-9-9-24
MAC
RAM 16gb
PT 11.3
003 Rack
MBox 3 Pro
Old 07-16-2004, 07:55 AM
Please correct me if I'm wrong, but it is an upgrade, but at the same time think about if you are buying a new product from digi. They will give you a cd with 6.4. I think that if you download 6.4 you also get the complete software program. Not the case of 6.1.1, which in fact it was only an upgrade.
Todo bien entonces??? Good.
Camilo Toledo
Old 07-16-2004, 09:46 AM
flautista's Avatar
Well Thaks for your help. If I have to reinstall in future, I'll try 6.4 standalone,now I know it works like that.Todo bien. Jascha K.
www.prodmusica.cl
GA-X58A-UD3R[/
I7 950
9-9-9-24
MAC
RAM 16gb
PT 11.3
003 Rack
MBox 3 Pro
D-Show standalone install problem jwilkens VENUE Live Sound Systems 1 03-09-2012 09:11 AM
Mbox 2 standalone, which drivers to install meliza11 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-20-2011 09:09 AM
2.8.1 Standalone Won't Install/Run Mike Sessler VENUE Live Sound Systems 31 07-09-2010 12:12 AM
Profire 610 Standalone S/Pdif Question with HD/192 JChance Pro Tools M-Powered (Mac) 0 05-06-2009 06:39 PM
Question about 5.3.2 standalone JimmyT 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-06-2003 08:48 AM
