Old 03-15-2004, 09:58 AM
rockwithrespect rockwithrespect is offline
Default Audio Midi Setup can\'t locate my device
I'm trying to add my Yamaha DTXpress electric drum kit in Audio Midi Setup. However, under the Yamaha pull down menu, the DTX series of modules is not listed. Has anybody else succesfully added this drum module? How did you do it?
I'm running a Dual 1.25 G4 w/ 1Gb RAM. Pro Tools 6.1 on OS 10.2.7 with a 002R
Thanks
Kyle
I've seen a million faces, and I've rocked them all.
Old 03-15-2004, 11:03 AM
Twinstream Twinstream is offline
Default Re: Audio Midi Setup can\'t locate my device
Add a new device and name it accordingly. Set midi channels send and receive. Set correct device id number. Search the internet for either a midnam file for your Yamaha or a OMS list of patch names. Search for cherrypicker which will convert OMS names to a midnam file. Place midnam file in correct folder and try it....
its 12:30 in the morning ...
are you going to bed?
G4 733 Ti 1Ghz 001 Mbox LE6.4 OSX 10.3.8 QT 6.9 XP80 XV2020 Midiman 2 POD2 Logic 6.43
Audio MIDI setup says DIGI 002 midi device is offline oliarnalds MIDI 17 10-23-2016 10:13 PM
MIDI Setup - Not seeing USB Audio Device as an Input Port Option oldtracy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-15-2013 09:22 PM
Unable to locate m-audio device ohio Pro Tools SE and Essential (Win) 5 01-09-2012 11:28 PM
Unable to locate M-Audio Device (Win. XP) lawdaproducer Pro Tools M-Powered (Win) 0 09-15-2009 08:10 AM
USB MIDI device connection - Mac Audio MIDI Setup jongilbertson MIDI 2 06-11-2008 10:13 PM
