Old 08-29-2019, 11:11 AM
Reckless Erik Reckless Erik is offline
Default Markers moved on session import
Having a strange problem when importing a session into a currently open one, that has the same timecode start etc.. The markers are moved to the front of the open session even though their position in the source session is different. BTW there is no offseting of tracks on import. This must be a bug of some kind. Anyone?
nickcath@internet.is
Newcomer Audio Post
MacBookPro 2.3GHz i7 16GB RAM OSX 10.14.6, PT 2019.6 HDn, Avid Artist Control, Avid Artist Mix...,
MacPro 3.5GHz 6 core 64GB RAM OSX 10.14.6, PT 2019.6 HDn, Avid Artist Control, Avid Artist Mix, PT Dock...
Old 08-29-2019, 11:46 AM
Default Re: Markers moved on session import
Did you NOT import the tempo?
Old 08-30-2019, 07:26 AM
No I did not. Is that the problem?
Newcomer Audio Post
Old 08-30-2019, 11:09 AM
BScout BScout is offline
You don't need to import tempo to import markers and have them come in correctly unless your markers time properties were set to Bars|Beats (by default they are set to Absolute which does not need tempo)
Pro Tools Ult 2019.6, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 08-30-2019, 01:41 PM
If markers are created when the main ruler is set to Bars|Beats, then they default to Bars|Beats, if the main ruler is Timecode, then they default to Absolute. I've been bitten by this a few times when jumping back and forth between rulers/timebases.
Scott Gatteño
Yessian
Old 08-30-2019, 02:27 PM
Right you are. Never noticed as I'm mostly in Timecode when setting markers.
Good thing for the OP is he can change his markers to Absolute if he opens the original markers (one by one) and swaps them to Absolute and then goes back and does the import.
Old 08-31-2019, 06:08 AM
Thanks Guys. I will check this out.
Newcomer Audio Post
Old 08-31-2019, 06:39 AM
That doesn't seem to be it. Sorry to report. Still offset to the beginning of the session.
Newcomer Audio Post
Old 08-31-2019, 11:18 AM
Can you post a screenshot of the import session data dialogue? I feel there's some pertinent info that might be missing that would explain this.
Old 09-02-2019, 06:05 AM
Here are the screenshots you requested with also a grab of the offline edit session and the master session. I have checked all the markers and they are all referenced to absolute TC. Still the problem persists.
Newcomer Audio Post
Save session, close session, open session next day...clips have moved. ptr22 Pro Tools 12 8 02-18-2016 06:34 AM
12.3 Event Markers can't be moved Scotty Chops Pro Tools 12 5 11-24-2015 02:06 PM
Audio Files Moved or Removed from Session after Saving Session Copy for Protools 9 doubtful guest Pro Tools TDM Systems (Mac) 1 02-06-2013 03:42 AM
Import markers Luzer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-21-2005 09:14 PM
Error Playing a Session Folder That Has Been Moved Matt_G Pro Tools TDM Systems (Mac) 5 06-14-2004 11:14 PM
