Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Win)
Old 05-03-2018, 01:23 PM
Hicham Chahidi Hicham Chahidi is offline
Default PT and RME FireFace 800 & TASCAM US2400
Hi everyone,
Actually i'm using Cubase and i would like to give a try to Pro Tools, so i am wondering if someone here uses PT on windows with RMe Fireface 800 or other RME interfaces?
I'm also using TASCAM US-2400 as a controller for controlling Cubase and Virtual instruments, anyone uses this unit with PT? I had a lot of troubles to make it working correctly with Cubase...
Old 05-04-2018, 05:29 PM
Default Re: PT and RME FireFace 800 & TASCAM US2400
Fireface should be fine with PT. RME is known for having the best drivers of any(assuming a compatible FW card or chip, TI being preferred and VIA often being a show-stopper). The Tascam has a HUI mode, does it not? It should just be a simple setup to make it work(get the unit to enter HUI mode, and enable it correctly under the Peripherals menu in Pro Tools). I bet a search of youtube would turn up a few tutorials on getting the Tascam working with Pro Tools(and the setup details will be essentially identical for any version of Pro Tools)
Old 09-09-2018, 12:41 PM
Thank you albee!!! Yes it works fine!
Hicham
Music Composer
Windows 7 64bits / 16 Go RAM / i7
RME Fireface 800 guitardom Buy & Sell 1 10-31-2012 07:40 PM
RME Fireface 400 and PT9? albertmacdonald Windows 4 12-08-2011 05:17 PM
RME Fireface UFX David Lang Windows 1 06-16-2011 07:13 AM
RME fireface-how can i use PT? damo701 Pro Tools M-Powered (Mac) 8 10-26-2008 01:02 AM
RME FireFace 800 Homebelly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-07-2004 05:34 AM
