Old 02-20-2008, 04:02 PM
willl3 willl3 is offline
Default Recording and getting latency when play back the rec track
I'm running protools 7.3 with 002
when I play guitar and record it sound like everything is in time but when I play it back it sounds off
I did with a recording and with only a click track.
is there something where its taking in the live sounds sooner than it can out put the tracks?
Slipping everything is too much work!
Help!!
and thanks
windows7 HP XW8400 Workstation Xeon Dual-Core 5150 2.66GHz 12gig ram
Old 02-21-2008, 11:51 AM
leadsticks leadsticks is offline
Default Re: Recording and getting latency when play back the rec tra
Help!!
and thanks
Yes, the buffer. Depending on the buffer settings you're using, the material gets recorded a little ahead. Check the required nudge values here (Buffer Settings and Latency Times):
http://music-production-school.com/p..._article.shtml
Old 02-21-2008, 07:30 PM
Where in protools do I find the latency set up for recording? thank you for the values
Old 02-22-2008, 03:41 AM
GeoffLee GeoffLee is offline
Default Re: Recording and getting latency when play back the rec track
Do you have any plugins on the master fader? Try disabling them, they could be making you hear the click and any other tracks 'late'.
Protools Studio 24.3, 2018 Mac Mini, Core I5 6 core, 16Gb ram, Sonoma 14.4, Focusrite Clarett+ 8pre, Focusrite Octopre.
Old 02-22-2008, 06:47 AM
sbag sbag is offline
do you have the low latency function on?
Gear>
C8, 002, Trigger Finger, Kontrol 49, Apc 40
SW >
Pt 8, Reason 5, Recycle 2.1, Ableton Live Suite 8.02
Plugs >
All Registered plug in's & Vinyl out the wazoo. Mp3 sucks
Old 02-22-2008, 07:32 AM
If you are using an Mbox, read up on how to use the MIX knob and mute track you are recording to(yes, it still records).
Old 02-22-2008, 12:33 PM
No plugs in nothing
like i said
im playing with just the click in time but when I play back its off
where in protools do I control latency?
There is nothing except a click and a guitar
where is the low lentency control?
Old 02-22-2008, 02:07 PM
the latency funtion is in the part where you turn on the pre roll and etc. it the the last option
at the bottom. im not at the computer so i cant excatly tell you where it is.
hope this helps
Gear>
SW >
Plugs >
Old 02-22-2008, 07:12 PM
No I don't have the low lantency on
when I play live to the click its on
when I play the recorded material back its off
Help!!!!!!!!!!
Please tell me where I can control this lantency problem someone else post where the pre and post are....... ok that doesn't help
I need to know where in protools LE 7.3 I go to fix a lantency problem
thanks
Old 02-22-2008, 07:30 PM
JMS40 JMS40 is offline
Hmmmmm... wonder what you'd find if you looked up the word "latency" in the index of the Pro Tools Reference Guide...
Page 263 of the 7.3 manual discusses all the options available to you.
How to Make my Midi Track Play Back EricMulhern Pro Tools 9 5 11-28-2011 12:19 PM
Most recent recorded track does not play back moody 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-26-2009 03:14 PM
Click track out of synch PTS 7.3.1 cs4 (Only in Play back) andre67 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-26-2007 02:41 AM
I Cannot Play The Track Back :( musicquizking 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-16-2007 08:26 AM
click track play back eldusto 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-27-2005 08:49 PM
