Mac System Sound through HD Native Thunderbolt Interface Headphone Jack
Hi there,
So I've got my Mac system sound going into the Omni just fine. Am able to hear it both through the analog outs of the Omni, and the headphone jack in front of the Omni, but not the headphone jack of the HD Native box. Any ideas?
Todd Niesen President, Captain Audio Sound Editorial |
Re: Mac System Sound through HD Native Thunderbolt Interface Headphone Jack
How are you getting the system sounds into the Omni? Do you have the HD driver in Audio/MIDI setup assigned to system sounds or are you routing it directly into the Omni with a physical cable?
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
I'm routing it directly into the OMNI with a digital cable.
Did you ever figure this out? I'm having the same issue/question!
The Omni has its own FPGA mixer for its ins going to outs that operate outside of Pro Tools. I'm assuming Captain Audio was using that mixer to route sounds when sending a digital signal from his Mac Pro to the Omni.
Unless the sound is routing through Pro Tools, it isn't using the hardware's return path to the native thunderbolt box (which mirrors Pro Tools channels 1 and 2.) So you won't hear it on the thunderbolt box's headphone out. Only on the Omni headphone out (which is the FPGA mixer.) There is no fixing this. To get it on the thunderbolt headphone out, after routing via a digital cable from the Mac Pro into the Omni, you would need to have an open Pro Tools session that then sends this input to the output of 1-2. That would then show up on the Thunderbolt headphone output. If you close Pro Tools, the signal will stop. With the Omni, there are two different mixers: The standalone mixer that is built into the hardware (and can operate with Pro Tools closed) and the Pro Tools mixer that is at work when Pro Tools is open. Only the second can be heard on the thunderbolt headphone output.
Thanks so much for the clarification! That has been vexing me for years!
Yes thank you BScout! Really appreciate your taking the time to explain it so well.
Cheers! |
remember... hd native thunderbolt headphone ALWAYS mirrors outputs 1-2
Right so if he used the avid core audio driver and routing the systems sounds to 1 and 2, wouldn't he get system sounds to the HD Thunderbolt headphone port?
Brandon Howlett Vibe Audio Post, Inc. Re-recording Mixer Custom Build CPU, HDX 1, Omni, 192 I/O Digital S6 M10 24 fader Satellite Mac Pro, HDNative, 192 I/0 Black Magic HD Extreme |
No sound through headphone jack | jpconques | Windows | 4 | 07-06-2018 04:24 PM |
Cannot play sound from iMac Late-2013 through HD Native Thunderbolt I/O 8x8x8 System | annaslwong | Pro Tools 11 | 4 | 03-18-2015 05:32 AM |
Not getting output from headphone jack on Thunderbolt Bridge | Cartoonmoon | Pro Tools HDX & HD Native Systems (Mac) | 1 | 09-03-2014 06:43 AM |
Mbox 3 Pro No Sound from Either Headphone Jack | unctuous | Windows | 1 | 09-16-2011 07:34 PM |
Can only get sound out of headphone jack on 002 desk | stevier | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 04-23-2010 02:43 PM |
